Citroen C5 X7 Tweeter upgrade
This section is for information and posts relating to Audio Head Units, and Navigation Systems
Costin33
Unread post by Costin33 »
Hello everyone! Apologies if I created the topic under the wrong forum.
As the title says, I want to upgrade my C5 tweeters with some aftermarket ones that I will be retrofitting. The thing is, I need to connect a crossover both to the tweeters and door speakers.
Can anyone help me with a wiring harness schematic of the audio system for the C5 X7? I want to know how and where the tweeter and door speaker cables are routed.
I also looked at SMEG's pinout and I don't see having separate outputs just for the speakers, therefore the cable should split somewhere in 2 -> speaker + tweeter.
Thank you!
Costin33
Re: Citroen C5 X7 Tweeter upgrade
Bump! If anyone knows where the cables are routed, it will be of great help!
x 1938
This is the Connected NAV & Connected Radio RCC telematics area of the forum. Can I suggest that you post your query here viewforum.php?f=3
