- x 6958
Ok so we're talking about the front suspension ball joint in the pivot.
(6) Suspension Ball Joint, part: 1635507580.
PSA do not provide measurements for these. Just order using the correct part number above and it will fit.
randomandy
We have just had the front windscreen replaced on our 2011 Peugeot RCZ (VIN: VF3**************[VIN obfuscated, can be read by forum staff]). The fitter broke the cover that goes over the sensor on the inside of the screen for the automatic lights / wipers.
Could you provide the part number for it please so I can see if I can track a replacement.
Thanks,
Andy.
Thanks,
Andy.
- x 1439
Took a bit of finding, but I think this is it, item 15:
6405RS - £21.64 inc VAT at the dealer.
randomandy
Thanks Richard,
That is indeed the part! Next time, I'll try to make it an easier part to find!
-Andy.
-Andy.
Pete_D60
- x 3
Happy Friday Guys!
Looks like I may have a misbehaving EGR on the Dogmobile!
Can you advise the correct part reference for VIN VF7**************[VIN obfuscated, can be read by forum staff] please?
Thanks,
Pete
Thanks,
Pete
Occasionally, I actually understand what I’m doing, however, now is not one of those times!
- x 6958
No problem:
(7) OEM Original EGR, part: 1618LN, £610.01
Standard Exchange EGR, part: 1638155380, £388.52
Pete_D60
- x 3
Cheers Marc!
Msig
Hello,
I'm having issues with the com2000 unit in my Xsara Picasso.
Could you provide the part number for a new com2000 unit, please.
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Homer62
- x 4
Hi,
Is it possible to get part number for my Citroen C5 20. Hdi 2006
Electric power steering pump. Vin VF7**************[VIN obfuscated, can be read by forum staff]
Thanks very much, I really appreciate this.
Davie
Davie
- x 1439
Was originally 6239PY replaced by 6242C5. Still showing as available, at £411.74Msig wrote: 12 Jun 2024, 08:04 Hello,
- x 1439
New 4007QG, exchange 1680909380 - but both are showing as discontinued.Homer62 wrote: 12 Jun 2024, 10:45 Hi,
Davie
Msig
That's grand, thank you.RichardW wrote: 12 Jun 2024, 12:24Was originally 6239PY replaced by 6242C5. Still showing as available, at £411.74Msig wrote: 12 Jun 2024, 08:04 Hello,
VIN is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Are there any other variations of that code?
I ask, as when looking at my current one and online most mention a 10 digit code.
Thanks again for helping!
- x 1439
Unfortunately not - it's common for there to be manufacturer's numbers on these sort of items which do not relate to the Cit part number (which is often not marked on the item!). If you are looking for a 2nd hand unit, then as you have seen it's probably best to go off the numbers marked on the unit, and get one that matches that number.
Msig
Okay, makes sense.RichardW wrote: 12 Jun 2024, 15:10 Unfortunately not - it's common for there to be manufacturer's numbers on these sort of items which do not relate to the Cit part number (which is often not marked on the item!). If you are looking for a 2nd hand unit, then as you have seen it's probably best to go off the numbers marked on the unit, and get one that matches that number.
Wasn't sure if the one currently in was correct, as there's been issues since I've owned it and its clearly been replaced once.
Much obliged for all the help!
citroenroen
Re: PART # FOR XANTIA LHM RESERVOIR / TANK
May I have part number for Xantia LHM Reservoir / expansion tank ?
VIN# for my car: VFX14D00004D1075
Is there is ONLY ONE reservoir for ALL Xantias? or are these varaiations ? If there are variations , what are the differences?
I have done the membership upgrade as requested previously.
"We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data "
Reason: Moved to Official parts thread.
