Pete_D60
x 3
Unread post by Pete_D60 »
Thanks Marc,
That’s much appreciated!
Presumably the sump gasket is only available as a gasket set then? :cry:
Occasionally, I actually understand what I’m doing, however, now is not one of those times! #-o
x 6963
Richard has chipped in (thanks Richard) between our posts Pete ^ and there isn't one which will be why it's not shown. :wink:
Pete_D60
x 3
RichardW wrote: 26 May 2024, 08:27 No sump gasket, it's sealed with RTV silicone.
Thanks Richard, that would explain it!
:wink:
danlat1415
x 24
Unread post by danlat1415 »
Please could I get the adblue tank part number?
VIN - VF7**************[VIN obfuscated, can be read by forum staff]
And also, if possible, the removal/replace procedure?
Thank you
x 6963
There are 2 possible tanks that could be fitted depending on vehicle so you will need to visually check. It should be easy enough to see though as the shapes are quite different:
Urea Tank A
(1) Urea Reservoir (see diagram for included parts)
New Original OEM Tank, replacement part number: 1682619980, £1022.04
Standard Exchange Urea Tank, part: 1682615480, £817.63
Urea Tank B
(1) OEM Original New Urea Reservoir, part: 1682620180, £1022.04
(no exchange tank listed)
I don't have the procedure for this engine, sorry.
508c5
x 4
Unread post by 508c5 »
Hi,
Looking for the steering rack part number for a Peugeot 3008, 2015, 1.6l, 165bhp vin VF3**************[VIN obfuscated, can be read by forum staff]
x 6963
Ok, so I can't actually add a new rack to parts as it won't allow me - so there may be an issue with getting new racks for these as I can't add them to an order.
The only one that allows me to add is a reconditioned one:
(1) Standard Exchage Steering Rack, part: 1663657380, £1107.48
508c5
x 4
GiveMeABreak wrote: 28 May 2024, 21:31 Ok, so I can't actually add a new rack to parts as it won't allow me - so there may be an issue with getting new racks for these as I can't add them to an order.
Narl
x 4
Unread post by Narl »
Looking the part number for the drop links on the 308 t9:
Vin: VF3**************[VIN obfuscated, can be read by forum staff]
idinabyxor
Unread post by idinabyxor »
Hi,
Peugeot Boxer owner here.
Im looking for the correct size on discs and brake pads.
Also looking for ball joint cone dimensions (found 20.5 and 24mm when searching).
VIN: VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Cheers
danlat1415
x 24
Can I double check something with you?
Part number 1682619980 is arriving tomorrow.
Many sale websites list part number 1682619980 as also 9818559280.
Can you check if they're the same part of if they're different?
I found the 9818559280 for £534.99 so almost £90 cheaper, so considering returning if it's the same part.
They suggest that all these part numbers are the same part:
OEM Number: 9818559280, 9813676080, 9808404280, 9808378080, 1682619980
x 6963
idinabyxor wrote: 29 May 2024, 15:21 Hi,
Cheers
@idinabyxor:
Front Brakes
(1) OEM Original Disc (Size Diam 280 EP 28), part: 1612435180, £151.52
Cheaper Peugeot Disc, part: 1687772280, £78.13
Front Pads
(3) Set of 4 OEM Peugeot pads, part: 1647863980, £190.64
Cheaper Peugeot Alternative, part: 1639374380, £60.20
Rear Pads
(1) Non-ventilated rear disc (size Diam 280 EP16), part: 1673602180, £117.05
Cheaper Peugeot Disc, part: 1686717480, £117.05
Pads
(3) OEM Rear Pad Repair Kit, part: 1673603480, £124.01
Cheaper Peugeot Pad Kit, part: 1675989880, £53.38
Steering Rack Ball Joint Gaiter
(3) Steering Gaiter Kit, part: 1610976280, £35.53
All prices are with UK 20% VAT included direct from Peugeot.
x 6963
Narl wrote: 29 May 2024, 14:45 Looking the part number for the drop links on the 308 t9:
Note: It won't allow an order for the original new drop links - only the cheaper version, so it may be they are no longer providing OEM new ones.
(2) Peugeot Cheaper Anti Roll Bar Rod, part: 1679755380, £19.78
x 6963
danlat1415 wrote: 29 May 2024, 16:59 Can I double check something with you?
I can only advise on the part numbers listed against your VIN and these will often be an original part number and a possible exchange part number.
Part: 9818559280 was the older part number for the original older tank. It has been superseded by a new tank for which 1682619980 is the replacement part number.
So I can only assume it has been updated and therefore is slightly more expensive.
I don't provide old part numbers as the whole point is to give members the latest parts which where they have been superseded are usually due to design improvements or fixes. :wink:
Of course I'm unable to provide you with details of the changes, so this is generally the reason. Citroen have both these parts at the same price, but if it were me I'd have the latest version in case it is an improved version.
idinabyxor
Thanks!
My second question was about the front axle Ball Joint, example OEM 364067 or 1635507580.
Im seeing two different cone sizes, 20.5mm and 24mm.
