Further to my messages to you recently re Service light
Indicator on my dash board. I have a Citroen Picasso C3 1.6 VTR 2011.
This light keeps coming on and off on my dash board. Yesterday it was off all day. But now it's back on to day.
I got a dinogstic test done on my car this mornning and the fault came up as . Intermittent Air Flow. But no code.
As I said I had my service done recently and all was ok. Changed filters oil and Air filter. And was reset
Can you be of any more help please.
Regards
Roy
Service light on Dashboard
PaulC5
- x 690
Re: Service light on Dashboard
Possibly there is a fault with the MAF (mass air flow) sensor or its wiring/connector. It could have been disturbed when the air filter was replaced. You could also check for an air leak between it and the engine. The MAF will be between the air filter and engine. On the parts diagram on this link it will be part no.10 https://www.ebay.co.uk/itm/275911546960 ... gIGfPD_BwE
- x 6945
I will need the fault code otherwise it is just guesswork.
- x 6945
I've deleted your other thread - please don't create multiple topics for the same issue as it duplicates answers. Please just update this thread in relation to this issue.
Regarding the Fault code you specified, see descriptors below. Although there is a long list of suspects, I would certainly check the Mass Air Flow Meter first and clean it with some specialist MAF cleaner first (Very carefully as the sensor wire is highly sensitive) and check all connections before moving on.
| Fault Code: | P3007 |
| Description of Fault: | Air circuit: Air flow lower than recommended. Ratio of measured airflow over calculated theoretical airflow below -15% detected for 2,5 seconds. Conditions of activation of the diagnostics The following conditions have to be met: - Air temperature between -20°C and 100°C - Battery voltage between 10 and 16 V - Turbo pressure between 740 and 1500 mbars - Engine coolant temperature between 50 and 100 degrees C - Engine speed between 1400 and 3000 rpm - Engine speed variation less than 16000 rpm per second - Air mixer open - Exhaust gas recycling valve closed |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
LEEDS
Thank you for your response. Apologies for duplicating them. Wasn't aware i was. Anyway just to finish. Whilst i appreciate your help . The car is driving great. No problems with acceleration. Temp or any if the problems stated on the list.
