x 2341
Re: Citrojim's AX, Pixo, C3, Running and Cycling Tales
Unread post by MattBLancs »
RichardW wrote: 15 May 2024, 09:51 I imagine the trouble with the sump plug is it has a 21mm hex, but only an M8 (?) thread, so it suffers from the gorilla syndrome problem.
M10x1.25 but yes, definitely!
It's a pretty weedy weldnut inside.
Interesting that "outy" one seems to be M16 too
x 8378
MattBLancs wrote: 15 May 2024, 11:28
I just priced a new sump plug and washer on eBay... Over £8 :o
Yes, M10 and 21mm hex is just inviting trouble :twisted:
More good work today, I had the airbox off and checked the injector clamps.
All at 45 Nm which seems reasonable...
Intrigued by this dry sooty mark on one corner of the underside of the air filter element :confused:
Any thoughts?
I'm loving getting to know Polly a bit more intimately... And how she's like a giant Lego set...
And finally this afternoon, after spending some quality time with my rapidly growing and chatterbox granddaughter, it was bath-time for Bluebell :D
She wasn't really mucky, just dusty from her winter hibernation...
Looking forward to taking her for a decent run tomorrow... A good check-over today revealed no issues...
Skull
(Donor 2026)
x 379
Unread post by Skull »
CitroJim wrote: 15 May 2024, 19:10
Any thoughts?
Isn't that where the induction pipe enters the filter ? Maybe just re-circulated exhaust fumes via EGR ?
Gary
x 8378
Skull wrote: 15 May 2024, 20:18
Any thoughts?
No, it's a way away from the EGR Gary... I have a theory after sleeping on it - and now having sooty hair :lol: I will discuss over lunch with learned friends and get a collective opinion...
x 2341
Any thoughts?
EGR normally a good deal nearer the inlet manifold (on 16v DV6 it's on the right side of inlet manifold on the part integral with the cam cover)
x 2341
Sump plugs about a pound on Autodoc (obviously the £8 p&p shifts the balance unless there's other things you need)
Mixture of M10 and M16 plugs listed (hence crude markup!) :)
x 8378
Thanks Matt, I need to work up a big Autodoc order ;) Trouble is, nothing much I need right now... Unless I stock up on AX spares...
We agreed, over lunch, the sooty patch on my air filter is brake dust - the air intake is in the inner wing and ideally placed to draw air in the vicinity of the brake caliper!
Yesterday I enjoyed a trip around parts of MK in this car :-D
Giggles per mile was off the scale :lol:
And in other news, I'm now looking into getting some 16" wheels for Polly so that I can fit some higher profile tyres... I have some potentials to look at...
Armidillo
(Donor 2022)
x 274
Unread post by Armidillo »
So you already know that 16" rims will fit over Polly's brake calipers?
x 2341
Armidillo wrote: 17 May 2024, 06:01 So you already know that 16" rims will fit over Polly's brake calipers?
A quick look suggests the C3 Picasso could be had with 15" - and I wouldn't rule out dropping 2 inches from the diameter.
https://www.ebay.co.uk/itm/276404652682? = 15" C3 Picasso alloys.
Need to look at the offset too, think it's likely similar to the 308, but worth checking up
x 2341
Some offset and wheel size info here:
https://www.wheel-size.com/size/citroen ... 16-hdi--99
Armidillo
(Donor 2022)
x 274
If your tyre availability is anything at all like ours, I wouldn't go below 16". I had to go up from 15" to 16" on my 406 D9 SV (Sedan) because the tyre choice for 15" wheels was so limited.
x 2341
Armidillo wrote: 17 May 2024, 07:28 If your tyre availability is anything at all like ours, I wouldn't go below 16". I had to go up from 15" to 16" on my 406 D9 SV (Sedan) because the tyre choice for 15" wheels was so limited.
Interesting! Was ok when I bought 205/60 R15 for the Coupe, but that was a couple of years ago. (Good range if brands available, went for Uniroyal Rain Expert)
Just had a look on BlackCircles.com and seems ok for 195/65 R15
https://www.blackcircles.com/tyres/195-65-15
x 8378
Thanks all, will be checking all before I take the plunge ;)
x 5673
Oponeo have a decent selection too.
Only one Sailun, which would be my preferred choice.
x 8378
Thanks Steve :) I won't go lower than 16" though...
And in other news, Autumn has now learning to drive... Her test is booked for next week :)
