Need diagbox 7.57 update
Stefax
Hi, is there any site where I could download the 7.57 update for diagbox? Most updates I have found are either 7.57+ or paid.
Kees
- x 147
Re: Need diagbox 7.57 update
You want it for free??
- x 6957
See the supplier of your diagnostic equipment, we don't supply software here.
- x 1942
What version of Diagbox are you currently on?
cit-rotti
- x 77
Whether further updates really make sense is rather unlikely - perhaps in very few individual cases 7.62 still makes sense.Stefax wrote: 12 May 2024, 16:45 Hi, is there any site where I could download the 7.57 update for diagbox? Most updates I have found are either 7.57+ or paid.
Although there are updates for DB V08xx that have been patched under DB up to 7.83, these are not fully functional. All updates after 7.62 are suboptimal and the original V07 software only went up to 7.65, whereby the last original updates were faulty and were fixed by the V08xx.
Anyone wishing to diagnose vehicles after 2015 should therefore install the 9.xxx software.
The software 7.xx incl. update could previously be downloaded free of charge from many forums - in the meantime, most of the links are unusable.
Try the following forums:
https://www.psa-diag.fr/forum/index.php
https://guiapsa.foroactivo.com/
Maybe it will still work there.
Greetings Wolfgang
Stefax
Stefax
Thank you, i will check forums.cit-rotti wrote: 12 May 2024, 21:14Whether further updates really make sense is rather unlikely - perhaps in very few individual cases 7.62 still makes sense.Stefax wrote: 12 May 2024, 16:45 Hi, is there any site where I could download the 7.57 update for diagbox? Most updates I have found are either 7.57+ or paid.
Greetings Wolfgang
- x 1942
If you haven't already sorted yourself out I have updates V7.XX to V7.44.exe, V7.44 to V7.49.exe and V7.49 to V7.57.exe.
Stefax
Thank you, I already found 7.57 on https://www.psa-diag.fr/forum/
LPGo
Hi all, I'm struggling. I've just bought a diagbox but the software don't work. The only which works is that my vinnumber pops up. Fill in the orga-number and then.
nothing happens. I'm currently running 9.85
My car is a 2005 C5 phase II do in my opinion is I should run the 7.57... Is there anybody out there who can provide it?.. I can't find a decent download and I'm scared putting money in it to download them, because I thing these are all fake or with virusses...
Thanks already..
Geo
Thanks already..
Geo
cit-rotti
- x 77
GuillaumeC57
[Request] APPDIAG.SYS File Generation for DiagBox 7.57
Hello everyone,
I'm currently installing DiagBox version 7.57 on my PC, and I'm stuck at the step involving the APPDIAG.SYS file. From what I understand, this file needs to be generated specifically for my hard drive using Scarymistake's tool.
I’d like to kindly ask for your help: would someone be able to generate an APPDIAG.SYS file compatible with my system?
Here are the necessary details:
- Hard drive name: SSDST256GBS33TMYSH ATA Device
- Hard drive serial number: 5453353232363235313533333439202020202020
- DiagBox version installed: 7.57
- Operating system: Windows 7 Professional 32-bit (x86)
Thank you very much in advance for your help
Best regards.
Best regards.
GuillaumeC57
Hello, does anyone have the tool I need to repair my appdiag.sys?
- x 1942
Are you hoping that there is such a tool or do you know for sure?
GuillaumeC57
The tool exists; back then, I even received my appdiag.sys file via email to unlock the Expert tab. Today, the 7.01 ISOs are either all unlocked, but incorrectly, meaning the Expert tab and troubleshooting are no longer available.
