Xantia - pre MOT woes
Jaf
x 42
Unread post by Jaf »
Whilst checking Fred over I found LHM leaks again. 1 at the rear, possibly the height corrector (changed it for a secondhand one last year), and 1 from from the pipe that goes from LHM tank to pump (couple of years old and made of horrible metal weaved-covered pipe). Shouldn't be too much trouble, except I lent on the coolant 3 way pipe/ pressure valve and snapped it. Sigh. Suppose that pipe has done pretty well.
Spare tyre has rotted! Oops.
Oh and Gwin, the AX, has a flat battery. Has taken a charge OK but it's not holding. Trying to work out if I can make it into town for a new battery. It's mostly downhill. Hmm. There's no buses or taxis round here!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
x 8457
Re: Xantia - pre MOT woes
Oh dear :( Here's hoping all resolves in a satisfactory way Jaf :)
Jaf
x 42
Thanks Jim. Making progress, if slowly.
Gwin's battery held a charge long enough to get into town. Got nice new battery. Driver's exterior door handle snapped! Superglue with reinforcing metal strips didn't hold, so have bought new araldite. When did that get so expensive?! Hopefully that will hold, haven't done it yet.
For Fred I've ordered 2 new tyres, will keep 1 old for spare. Been nearly a week. Hmm. Changed LHM pipe, not convinced it's any good as the larger pipe is marked as nautical! Going to try a different shop. Still had a leak at pump, cleaned up pump is so shiny it's hard to see the leaks. Anyway eventually decided it's 1 of the star key seals. Last changed by a garage around 15 years ago. And was not tight. Fingers crossed that is the front leak sorted, still looking ar rear leak.
Jaf
x 42
Forgot to update this. Took Xantia Fred for inspection, I do so enjoy the spanish brake test! Passed with advisory on LHM drip at rear. I've ruled out both suspension cylinders and the height adjuster so think the fluid must be coming up from the front. Something to look at!
Ax Gwin, door handle glued up nicely with Araldite...only to fall apart after 2 days. Going to use teeny screws instead.
x 8457
Good news on Fred's inspection success Jaf :D
