DS3 Crossback passenger door handle stuck in open position
Alli55
Re: DS3 Crossback passenger door handle stuck in open position
Unread post by Alli55 »
I have taken the car to peugeot main dealership and an independent garage and they have found no fault the independent garage did say that it could be the handles or the module and I should take it to ds dealership it is booked in on thec11th June will they be able to diagnose it and find the fault as my door handles won't come out on unlocking the car
Alli55
My car door handles wouldn't pop out on unlocking in the rear front door handles would sometimes work and sometimes not. I took it to a ds dealership on the advice of ds customer care and it should that due to an fault with the bsi the handles were faulty and need replacing. It's a good job I have an extended warranty as it would have cost me £2048.68 to get them all replaced. They were actually covered under the warranty.
x 6955
Shocking to be honest.
The more tech, the higher the failure rate is likely. Give me standard door handles any day!
