moomoo
- x 9
part number
Hello
could anyone help me out with the part number for the 1998 peugeot boxer 1.9td injector pump cradle/carrier/support bracket please.
Reason: Moved to Parts Thread
- x 6945
If this is for your VIN ending 475, then let me know the specific item numbers from the diagram below for which you want part numbers:moomoo wrote: 25 Apr 2024, 13:46 Hello
Please ask for any future parts in this thread.
moomoo
- x 9
Hello Marc,
Its the cradle itself...Looks like prt number 9 in the diagram.
thanks.
thanks.
- x 6945
(9) Injection Pump Bracket, part: 192684, £253.82 Direct from Peugeot inc. VAT.
moomoo
- x 9
Hello Marc
Would you happen to know (beside the part number) if theres a difference between part number 192684 and 192640...
Has one part number superceded another?
The two parts look extremely similar....
I can get hold of the 192640 part quite easily second hand.
Martin
Martin
- x 6945
We only provide the correct parts for the VIN.
In this case:
192640 was up to build 09883, (30/11/2003)
192684 was from build 09884, (01/12/2003) and your build date is 10690.
So you vehicle build date and VIN states 192684 is correct for your build date. 192640 is for vehicles before this date and is not a superseded part, it is a different part.
In this case:
dtsaop
Hi Marc,
I have an accident with my citroen Berlingo (K9) and i had to replace the left front and slide doors. Is it possible to provide me with the part numbers for the both doors, the door protectors and the black sticker that is installed at the front door (an image is attached)
The VIN: VR7**************[VIN obfuscated, can be read by forum staff]
Many Thanks,
D
Many Thanks,
D
- x 1490
Front door:
The trim, item 16 is 98184664WS.
Side door:
Yours is fitted with side trim item 31 which is 98184661Xt
Side door:
DaveS
Hi,
Could I please get the part numbers for timing chain/cam sprockets/guides/tensioners as well as oil pump, drive chain and guide for the VIN VF3**************[VIN obfuscated, can be read by forum staff].
Many thanks in advance!
- x 6945
(1) Camshaft Gear, part: 0805H3, £56.60
(3) Timing Chain, part: 9677427780, £136.26
(6) Timing Chain Guide, part: 9675805880, £14.11
(8) Timing Tensioner, part: 9675777680, £76.60
(10) Timing Chain Guide, part: 9675805980, £18.90
(12) Timing Chain Guide, part: 081827, £15.31
(1) Engine Oil Pump, part: 9808634180, £329.11
(4) Engine Oil Pump Chain, part: 103315, £51.82
(5) Oil Pump Chain Tensioner, part: 103318, £43.48
DaveS
Thanks Marc, youre a diamond!
dtsaop
Many thanks for the reply. That was a great help.RichardW wrote: 26 Apr 2024, 20:07 Front door:
Side door:
Is it possible to also send please the part numbers of the door sealing for both doors (number 13 and number at the front and back door respectively) and the engine top cover.
Many Thanks again
- x 6945
(13) Front Sealing Panel
Left, part: 9819576080, £29.26
Right, part: 9819575980, £29.26
(40) Sealing Panel
Left, part: 9817691680, £23.44
Right, part: 9817691880, £23.44
(40) Sealing Panel
rtakah
Hi! Looking for the OEM number of the pipe with the red circle.
And if it possible the next pipe after the part number 3 in the image. Thanks!
- x 6945
(3) Air Hose, part: 9806469680, £214.52
