Hello. I have done lots of research on diagnostics kits and was just about to buy Diagbox 7.57 with Lexia 3 when I read the warning posted on this forum by GiveMeABreak.
All I want to do is clear fault codes and understand, as far as possible, what is wrong with my car before going to a garage. Mileage on my 2012 Semi-auto Berlingo is 47000. I have had repeated 'risk of clogging' warnings that have gone away after giving the car a good run. Currently, this fix is not working, performance is reduced and the engine fan runs continuously. This is the only problem I have had with the car in 3 years of ownership.
Will Diagbox 7.57 tell me how much soot there is in my DPF? I know Lexia 3 has been discontinued. Is there a newer interface that will help me diagnose my DPF problem?
I've spoken to several garages - some tell me I've got a gearbox problem, others that I need a DPF clean. I've not paid anyone to do a diagnostic yet. Very grateful for help.
DPF Diagnostics - Berlingo 2012
- x 1489
Re: DPF Diagnostics - Berlingo 2012
7.57 should be OK for a 2012 car. You'll need to see the codes and live data to try and figure out what's up with it.
- x 1938
7.57 was OK on our 2013 X7, so I'd say yes as well. Having said that I took it a bit further to 7.58.
Freedom54
Thanks Paul-R.
