I have a problem with a leak of gearbox oil from the driveshaft seal. I need to buy new seals, my confused by which ones I need. Can anyone help provide me with the part numbers and the replacemnt oil required. It's a citroen c4 GP 1.6 diesel semi automatic.
Vin: VF7**************[VIN obfuscated, can be read by forum staff]
Leaking gearbox oil
- x 2543
Re: Leaking gearbox oil
You do need to be a little careful getting the correct ones, some are both sides the same others two different sizes depends on the box.
Cheers, I have it sorted now, a Citroen dealer eventually called me back and provided the part numbers I need. So ordered from GSF.
