aljohnstone66
VIN VF3**************[VIN obfuscated, can be read by forum staff] 2003 307 S HDI 1.4 3A/C
It's chewing offside front wheel bearings. To hopefully finally solve the problem I've decided to fit a new complete pre-assembled offside Steering Knuckle and Hub Bearing Unit (Knuckle Hub Bearing Carrier+ Bearing+ Wheel Hub). There are several sources on ebay, but there are discrepancies between them as to whether or not their parts fit the diesel models. The allegedly oem part numbers being quoted are 364796, 1606631080, 330785, 3307A0. Can you check that these part numbers fit my model?
Many Thanks ALJ
Many Thanks ALJ
- x 6947
Hi, these are the official part numbers for your vehicle, but can't comment on after-market databases as they're not very accurate in many cases.
Front Axle
(1) (A+B) Front Stub Axle Carrier (Right) part: 364796, £475.98
(3) Front Wheel Hub, part: 330785, £185.14
(4) (B + 14) OEM Front Hub Bearing Assembly, part: 335069, £142.06
(B) PSA Bearing kit 1681935280, £31.38
Steering
(3) OEM Tie Rod Assembly, part: 3812E0, £63.38
PSA Cheaper part: 1689110380, £28.25
(4) Steering Gaiter Kit, part: 406673, £33.12
(5) OEM Ball Joint Kit (Right), part: 381741, £106.24
PSA Cheaper (Right) Part: 1607316280, £16.05
Let me know if I've missed anything.
Front Axle
Steering
aljohnstone66
Spot On Marc. Many Thanks. ALJ
Jackies Dad
Re: Boxer 1.9D Vin Decode
Good Morning Marc ?
Absolutely brilliant-just what I was after !! As for parts, I am needing a complete exhaust system and probably a gearbox as the Synchros are shot mainly on 1st & 4th. When I drained the oil it was somewhat silver in colour !!! and the plug had lots of filings on it ! So--The search begins !!
Best regards.
Best regards.
Reason: Moved to the Official Parts Thread
- x 6947
Please note 'NFP' = No Longer Available from Peugeot.
EXHAUST SYSTEM HEAT SHIELD
(1) Exhaust System Heat Shield, part: 173214, £51.68
(2) Bold, part: 173213, £1.44
FRONT CATALYTIC EXHAUST MANIFOLD
(1) Manifold, part: 0341A2, (NFP)
(2) Manifold Gasket, part: 0348J0, (NFP)
(3) Pipe Spacer, part: 035307, £2.24
(4) Flanged Nut, part: 9828649080, £0.40p
(11) OEM Original Exhaust Front Pipe, part: 1706X5, £113.36
Cheaper PSA Front Pipe, part: E12882H, £98.06
(13) Exhaust Fixing Kit, part: 179875, £43.50
(14) Washer, part: 171228, £3.01
(70) Self Locking Nut, part: 693586, £0.40p
(71) Stud, part: 693092 (NFP)
INTERMEDIATE AND REAR EXHAUST
I've only listed the rear silencer here - if you need any of the other items, let me have the item number.
(1) Rear Silencer, part: 9678161280, £626.63
Jackies Dad
Hi, I am looking for the correct part number for a complete exhaust for my 2002 1.9 D Boxer motorhome -Vin info states no Cat Converter.
Also looking for new or re-conditioned Gearbox --Vin Info for gearbox is Bvm M15t
Any help much appreciated.
- x 6947
I've listed the parts for the exhaust above ^^^^^ There is no such thing as a part number for the complete exhaust, only the individual components as per the diagrams shown above.
Gearbox
(1) New Gearbox , part: 2222E9 (no longer available new).
Markings: CP(14X75)-CT(27X21)P
MARKING LE20 UE01 (LE20) LE36 (LE36) (UE01)
Gearbox
danlat1415
- x 24
Please could you find the front door handle part numbers for VF7**************[VIN obfuscated, can be read by forum staff]
The door handles have the keyless sensor on them.
As there are many different variants, I want to ensure I get the correct part numbers
(Both passenger side and driver side front parts please).
Thank you
Thank you
- x 6947
(2) Door Handle
These are with hole and are supplied unpainted.
Left, part: 967853211T, £195.04
Right, part: 967853191T, £195.04
Jackies Dad
Hi Marc,
Many thanks for the exhaust & gearbox info. Much appreciated !
Huskyxantia
- x 927
Hi Marc , the connectors on the vacume pumps which have the hex bolts can these be purchased on there own or is it a complete part, if they sell these connecting pieces what the pipes push on to whats the part numbers. Thanks
The plastic connections what the hoses clip on to
2012 1.6hdi engine. VF7**************[VIN obfuscated, can be read by forum staff] for above
Reason: 3 Posts merged
Husky.
- x 1496
Pump is only shown complete, what bit are you trying to replace?
- x 6947
(1) Mechanical Vacuum Pump, part: 9850109580, £173.29
- x 22
Hi Marc
re my 2.7 407 diesel
could I get official part numbers for no 19 and 20 in the pic.
I assume the pump number is 1920HJ
thanks
thanks
- x 1496
1920 HJ is correct for a new pump (£1830.76), exchange is 1921N9 (£1287.46). PSA don't supply the parts separately unfortunately!
