EML on
Miapops50
EML on
Unread post by Miapops50 »
Hi I’m not sure if I’m on the right part to ask a question about my Citroen C3. I’m not very good with things online. I have a 2014 Citroen C3. The EML came on 5 weeks ago. The RAC said I needed a new lambda sensor so took to garage and had this done. 2 days later light came on again and RAC said my spark plugs were broke so paid for 3 new ones. Next day light came on again, took it to garage and ended up with new coil pack being fitted and second lambda sensor and next day light is back on. Any ideas in what this is as I have spent £500 so far. TIA
x 1061
Re: EML on
Unread post by wheeler »
Miapops50 wrote: 21 Apr 2024, 14:10 Any ideas in what this is as I have spent £500 so far. TIA
Not really without at least a fault code as a hint.
Miapops50
Re: EML on
This came up on one of the diagnostic U1218 CAN BSI Communication Fault - permanent
Miapops50
Re: EML on
Also just now the seatbelt light was flashing in and off even though seatbelt was on. Could all these problems be a faulty ECU
Miapops50
Re: EML on
Thanks for all the helpful replies!!!
x 1083
Re: EML on
Unread post by Rp0thejester »
This is a puzzle...it could just be down to a loose electrical connection. If all those parts have been replaced and still not sorted the problem then that's what I'd go with. I would of initially checked the connectors to everything. And do a complete reset of the system. Citroens are known to have funky electrics
