List of equipment
x 6961
Re: List of equipment
We can provide the factory build sheet which lists what it does have equipment wise, i.e. type of gearbox, engine code, engine serial, cruise control, type of Head Unit, etc. paint code, upholstery, parking assistance type, blind spot..... Note that this won't be the same 'customer speak' that you will get in a sales brochure, just the key components.
Nhokas
Unread post by Nhokas »
GiveMeABreak wrote: 23 Mar 2024, 22:02 We can provide the factory build sheet which lists what it does have equipment wise, i.e. type of gearbox, engine code, engine serial, cruise control, type of Head Unit, etc. paint code, upholstery, parking assistance type, blind spot..... Note that this won't be the same 'customer speak' that you will get in a sales brochure, just the key components.
That would be enough
x 6961
@Nhokas: Check your email in a minute.
Nhokas
GiveMeABreak wrote: 09 Apr 2024, 16:01 @Nhokas: Check your email in a minute.
Did not received any...
x 6961
Sent on the 9th April at 16:06. Check your Junk and spam folders.
Nhokas
GiveMeABreak wrote: 18 Apr 2024, 17:34 Sent on the 9th April at 16:06. Check your Junk and spam folders.
Spam checked but nothing there...
x 6961
Sent again now, using your Forum email, but in case there's still an issue, I've posted it here:
Vehicle characteristics
Vehicle familyDS 7 CROSSBACK (X74)
AS/RP N°16419 88 1 0112
Warranty Start Date06/05/2022
Engine serial number10 FKBJ 2847340
OPB00JJ
BERe2*2007/46*0601*18
P4A9833386599
General information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEDS
VEHICLE FAMILYDS 7 CROSSBACK (X74)
SILHOUETTES.U.V.
TRIM LEVELUPPER MEDIUM
ENGINEEP6FADTXHP 1.6L PETROL
TRANSMISSION4X4 8-SPEED AUTOMATIC HYBRID
PAINT TYPEMETALLIC LACQUER
BODY COLOUREVL - PLATINUM GREY PAINT
INTERIOR TRIM TYPENAPPA LEATHER "4H"
UPHOLSTERY COLOUR"FO"
GEARBOX (CHARACTERISTICS)EATNG8
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)EP TYPE ENGINE
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
BADGEE TENSE 4X4
Fuel supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAPWITHOUT FUEL FILLER CAP
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 6.3 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNALFRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY1600 CM3
CATALYTIC CONVERTERCATALYTIC CONVERTER BELOW 50PPM
FUEL TANKPRESSURISED WITH LOCATING TAB
COOLING MOTORRADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)ENGINE POWER 147 KW - 300 NM
SPECIAL POWER TRAIN SOUNDWITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FANVARIABLE SPEED FAN 200W AERO DYNAMIC FLAP
DRIVE TRAINPHEV DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
FINAL DRIVE RATIOFINAL DRIVE RATIO 15 X 58
WHEEL STYLESTYLE5 20 INCH ALLOY WHEEL
CLUTCHWITHOUT CLUTCH
RIM/TYRE SIZE20 INCH TYRE FIT
TYRE (SIZE, TYPE)TYRE 235/45 R20 100V NON-REINFORCED
DRIVING WHEELS4 DRIVEN WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
GEARBOX TYPEGEARBOX TYPE EATN8
Suspension-Steering-Brakes
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR DIAM 17.5
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR STIFFNESS 37500 NM/RAD
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEWITH STEERING ANGLE SENSOR
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTBOSCH 9.3 ESP
STEERING (OPERATION)HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)PEDAL ALUMINIUM
Body fittings
TOWBARWITHOUT TOWBAR
HORNSHORNS-HARMONY
SIDE MOULDINGS (TYPE)CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION)THIN LATERAL/SIDE PROTECTORS+BODY SILL CHROMED DS
WHEEL EMBELLISHER (STYLE)BLACK CAP
EXHAUST TAILPIPEREAR RIGHT AND LEFT EXHAUST OUTLET
UNDERBODY SHIELDDEFLECTOR UNDER FRONT FLOOR
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER+PASSENGER ELECTRIC FOLDING+DIODE+MAR+MEMORY+EL
EXHAUST TAILPIPE TRIMCHROME EXHAUST OUTLET TRIM
WINDSCREEN GLASS (TYPE)HEATED WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPERW/O HEADLAMP WIPER
ROOF GLASSWITH SLIDING TILTING ROOF WINDOW ONE-TOUCH CONTROL ANTI-PINCH
BUMPERBODY COLOUR FR BUMPER+GLOSS BLACK GRILLE+BODY COLOUR RR BUMPER+PAINTED BEAD
NUMBER PLATEWITHOUT LICENCE PLATE
FRONT FOGLAMPLED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AIDFR PANORAMIC VISUAL ASSISTANCE + RR VISIO PARK 2
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESCHROME+BODY-COLOURED EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
BUMPER TRIMBUMPER WITHOUT TRIM
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE)ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
HANDS FREE ACCESS AND STARTINGWITH HANDS-FREE ACCESS/STARTING
Interior fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTERWITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEATSEAT CUSHION+BACK 2/3-1/3 FOLDING
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
CABIN SEATWITHOUT CAB SEAT
LUGGAGE COVERSHELF
ASHTRAYWITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP)COLD COUNTRIES
AIR CONDITIONINGWITH HEATER MATRIX
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
GEAR SELECTORRAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL
DRIVING POSITIONLEFT-HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGLED STORAGE COMPARTMENT + GLOVE BOX LIGHTING
DASHBOARD EQUIPMENTPADDED LEATHER DECOR DASHBOARD
MISC. INT. LAMPSPOLYCHROME AMBIENCE LED LIGHTING
INSTRUMENT PANEL (CHARACTERISTICS)DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
CHILD SEAT ANCHORING POINTSWITHOUT ANCHORAGE WITH ISOFIX FR AND RR
LOUDSPEAKER4 HP FRONT (2 TW + FR) + 4 HP REAR
ADDITIONAL BLOWERWITH ADDITIONAL PULSE
POLLEN FILTERWITH POLLEN FILTER + ACTIVATED CARBON
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROLDRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROLPASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENTTILTING SEAT BACK ELECTROPNEUMATIC LUMBAR SUPPORT+MEMO
FRONT SEAT ARMRESTFRONT CENTRAL ARMREST FLOCKED + LEATHER
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSLED BULB
TRAFFIC INFORMATION READERPREVENTION+TRAJECTORY CENTRING LPA
DISPLAYDGT TOUCHSCREEN+12" DFT DISPLAY
CLOCKANALOGUE CLOCK
COURTESY MIRRORDRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTRESTALU DRIVER’S FOOTREST
OIL GAUGESTD OIL LEVEL INDICATOR
HEATING ELEMENTDRIVER AND PASSENGER HEATED + VENTILATED SEAT ROW 1
FRONT LATERAL AIRBAGFR CHEST/PELVIS SIDE AIRBAG+CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER + FR PASSENGER FOOTWELL LIGHTING
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
WIFIWITH WIFI
RADIO RECEIVERDIGITAL CONNECTED NAVIGATION
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLSPEED LIMITER ACC STOP AND GO REGULATOR
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORFRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
CARPET COVERCARPET MAT 1
LOAD SPACE STORAGERETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDINGWITHOUT RR PASSENGER DETECTION
TUNER RADIOTRI RADIO TUNER
OBSTACLE DETECTION SYSTEMFRONT-REAR RADAR OBSTACLE SENSOR
TRIM ADAPTATIONLEATHER GEAR LEVER KNOB + LEATHER GAITER
FLOOR MATFR + RR MATS
EQUALISER AMPLIFIERAMPLI EQUALISER WITH PREMIUM 12 CHANNELS
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLNORMAL + AUTOMATIC LOCKING
STEERING WHEELSPLIT LEATHER STEERING WHEEL + DECOR
SEATING ASSOCIATED VARIANTVARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKET3 USB PORTS
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATORISTT60
HORNSHORNS-HARMONY
BATTERYL2 680 60AH EFR 680 BATTERY BECOMES EF
STARTER MOTORWITHOUT STARTER MOTOR
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY)STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGERSINGLE-PHASE 7 KW ON-BOARD CHARGER
MULTIPLEXINGR3 INT ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUGT2 CABLE SOCKET E/F
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
CONDENSER (SPECIFICATIONS)CONDENSER 23,5DM2 THICKNESS 16
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETDOUBLE ACCESSORY SOCKET
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
EMERGENCY WARNING TRIANGLEWITHOUT WARNING TRIANGLE
Nhokas
Thank you
MurrayP
New User
Unread post by MurrayP »
Has anyone solved the issue of the drop in battery mileage range? I have purchased a 72 plate DS7 360 ETense and the battery mileage range is between 16 and 19 limes on a 100% full charge. I have received the cold weather routine from the garage who supplied, it but never the less, they sold it to me with the pitch that it would do 36 miles on a full charge, and that was in their sales literature. It doesn't do what they said it would. I have had the charger checked at a DS dealership and it is not faulty, so it must be the battery. Does anyone have any useful help they can give? The DS website currently states it will do 68Km on a full charge ! I have had the car for three months and drive steadily.
x 6961
This won't be the first example of totally unrealistic Hybrid Performance. I can't help you, as most of the claimed mileage is pure fantasy in the real world.
