Help
- x 6950
Re: Help
The gearbox ECUs on these vehicles can also be paired to the engine ECU. If you have changed to a different engine ECU or the engine is not identical, then it can stop the car from starting as you can see from the diagnostic information - the engine ECU is not authorising the starting of the vehicle as it's getting the request from the gearbox ECU, but not the authorisation.
- x 5688
