seanrx
x 6
Unread post by seanrx »
On eBay, part no. 6554F1 boot switch is listed for a 2000-2008 C5.
6554F1, can you search for this also please? May actually be for a MK3. Need to be sure.
x 1449
That appears to be for the estate, I would read part 13 (8726Q8) 'Opening external control' to be the handle / microswitch for the hatch back.
x 1006
Unread post by Rp0thejester »
Can I get the part number for my C8s Auxiliary belt please? The one that runs the pumps and squeaks like fing hell.
seanrx
x 6
For estate? Many thanks.
I visit the Citroen parts.co site. No parts for my car, not even the glass, struts or even the emblem!
I'll visit their garage, see what they have.
x 1006
Hmm, Citroen, we all have the same problem buddy, obselete is there favourite word
x 6960
(20) Alternator Belt:
OEM, part: 5750VS, £54.85
Cheaper, part: 1606353880, £21.46
This is for the belt only, although they do supply the belt and idler / tensioner kit shown at (50), Ancillary Belt Roller Kit, part: 1613443180, £63.30
The kit is the cheaper version as the OEM one is no longer available.
earlsgate
x 6
Unread post by earlsgate »
looking for part numbers for my front callipers, on the heavy 435 version of the Boxer van, that has 16" wheels
thanks in anticipation
x 1449
Assume for VIN ending 692:
New
4401 BRAKE CALIPER CYLINDER LEFT
16 078 768 80 RIGHT
Exchange
16 517 662 80 STD EX BRAKE CALIPER CYLINDER LEFT
16 517 672 80 RIGHT
New around £600 each, exchange £330 each (not the same price left / right in both cases!). £72 surcharge applies per caliper in both cases.
cncjeff1
Unread post by cncjeff1 »
Good Evening,
Once again, the culprit is a 2016 Berlingo, VIN VF7**************[VIN obfuscated, can be read by forum staff].
The AC compressor appears to have locked up, or the pulley and clutch self destructed. I would like the part numbers of the compressor, pulley, and clutch, as well as the serpentine belt. By any chance, would your source materials show the center dimensions of the crankshaft pulley and the alternator pulley. If possible, I would like to fit a belt just on those two pulleys (while I wait for the compressor to arrive. Thanks in advance.
Best Regards,
Jeffrey
x 6960
Clutch is not available from Citroen, only the complete compressor.
There are several choices, depending on what you have fitted, and there is a refundable surcharge on these when the old one is returned.
(1) New OEM Compressor (DENSO THERM SYS - 5SEL12) , part: 9819714980, £1044.23
(1) Standard Sanden Exchange Compressor, (SANDEN INT- - SD7C161341), part: 6453ZC, £643.43
(1) SANDEN INT- - SD7C16 C1P4 1321, part: 1631054580, £631.44
Alternator parts are as follows:
(4) Alternator Pulley, part: 1611503780, £62.46
(20) Ancillary Control Belt (K6-LE 962), part: 9803580580, £38.08
(60) Alternator Pulley, part: 1622780280, £161.90
dave101ua
Unread post by dave101ua »
Hello!
Could you please give me part number for the number 14 shown in the picture below ?
Also please number for stabilization front right (please see the attached image)
and also parts for the Axle boot front both left and right (please see attached image)
Thank you !
x 1449
Balljoint 9803434080 (£78.32) or 1682729480 (£17.15) cheaper alternative. Not handed.
Roll bar link 9844264780 (this is a replacement part and it lists 9817224280 as well but doesn't say what it is!). 1679755380 (£19.78) cheaper alternative. Not handed, won't give me a price for the original ones.
Driveshaft gaiters 3293C7 (I think, not clear which end is which!) £56.33
I wouldn't fit the OE roll bar links, or gaiter kit - Meyle HD links are much longer lived, and aftermarket boot kits tend to be stretchier and easier to fit.
dylan26__
x 22
Unread post by dylan26__ »
Can I get the spark plugs for our puretech please
x 6960
(2) Spark Plug, part: 9829930180, £29.05
dylan26__
x 22
GiveMeABreak wrote: 14 Jan 2024, 11:29 Yes, I checked 3 times, and with your VIN it is removed. Not sure of the reason for that, so hence a check with Citroen.
if you're interested, i just got off the phone with citroen about this and they had the exact same issue as you. Said they can't find the part number on their system
