x 2367
Unread post by MattBLancs »
Huskyxantia
x 928
Unread post by Huskyxantia »
:rofl2:
:-D
x 8156
Having listened to the song Matt the lyrics quoted are not right!! '....fruit shop for a pear' is much better, and there appears to be a verse missing altogether!! :-D
x 2367
308 SW's condition (which seems fine now) seems to be contagious, here's the C5's dash this morning:
Too low
Too low
Huskyxantia
x 928
How much fuel in the tank matt, ive noticed my 308cc throws up this when its less than a quater, i undo the filler cap let the vacume out and then a run to fill her up part motorway and a roads plus a fresh spritly run of 20,30 mile above 40mph , alls good after.
:-D
Huskyxantia
x 928
Roll on warmer weather dpf off , jet wash out ....
:-D
x 2367
Fuel tank about a quarter at present, but it's run this low or less every tank and normally fine.
Did it before I had left the drive, so think it's the additive countdown has reached zero / additive remaining figure (calculated) that is triggering the message.
I'll plug in tonight and get the lowdown from it's "brain" :)
x 2367
Huskyxantia wrote: 02 Apr 2024, 10:12 Roll on warmer weather dpf off , jet wash out ....
I'll check the DP readings with engine running too tonight, if they are ok will leave it be for now.
This one looks more sensible to jet wash as straight pipe outlet (so better access to then reverse flush/squirt at) but also have the bottle of Wynns Off Car DPF cleaning stuff to try too.
x 8156
I always used to use Brick Acid from B&Q, about £12 or so for 5 litres. Huge saving v proprietary DPF cleaners and just as good!! :-D
Huskyxantia
x 928
I did the wynns soak over night on the 206cc when i had it you should of seen the muck that came out the thing ! When checking my 308 last month i had 875 mls left in the aditive tank which holds about a litre so it uses very little over the course of a yr, what i like about the dpf on both cars now is the sensor can be removed and cleaned that way. Works a treat very quick too. Also handy for an enderscope aswell
:-D
x 2367
Quick dump of information
Particular filter parameter measurement
Idle speed
771 rpm
Difference in pressure between particular emission filter input/output
000 mbars
Approximately 3000 RPM
016 mbars
x 2367
Clear the faults then followed the following path to tell it the additive tank has been refilled:
Repair
Pack repair
After sales particular emission filter repair operation
Replacement of the particular emission filter and work on the additive adding circuit
Filling of the diesel additive adding reservoir
Huskyxantia
x 928
Check this & read some of the commemts
:-D
x 2367
Huskyxantia wrote: 02 Apr 2024, 21:28 Check this & read some of the commemts
Yes I watched that very video whilst digging into the 308's issues! Thanks.
Code clearing seems ok, will see how it performs tomorrow on my commute to the office and back, will update same time tomorrow
x 2367
Quick upload of the DiagBox print screens
A
A
B
B
C
C
D
D
E
E
F
F
G
G
