- x 6962
Ok, so weirdly, only the left one is coming up for your VIN, part: 9829740680, £197.58
However, if I remove the VIN-specific filter is does show the right side protector (with the rectangular cut-out) as part: 9805062180, £196.31
So if you are sure it has both, then these are the parts for the vehicle's build date, but may be worth querying why the right one is not showing up in parts....
MJJ_ZX6RR
- x 9
Magnificent, thank you Marc - I can get these sourced now. Just for info, and in case it helps someone in future, I can confirm the car has both of these fitted - the 9829740680 (no cut-out) is the broken piece that fell off recently and that needs to be replaced, the 9805062180 (with cut out) remains correctly fitted on the car.GiveMeABreak wrote: 31 Mar 2024, 16:43 Ok, so weirdly, only the left one is coming up for your VIN, part: 9829740680, £197.58
Martin.
Helping my daughter with her first car, a 2016 DS3 Prestige 1.6HDi 120 (S/S) - 160,000 miles.
I have some high mileage german stuff, and a selection of motorbikes.
- x 6962
Great, probably an error on PSA's side then, thanks for confirming Martin.
danlat1415
- x 24
Please could you find the part number for my upper engine cover?
Thank you
Thank you
- x 1456
9805762880 including new rubber mounts, £83.62
drayton11
Hi
Is it possible to get the part number if it's available seperately for the gearbox linkage end that fits onto the Aisin EAT6 box. I have a very sloppy gear lever that takes a number of attempt to select D. The end linkage is very loose & I think it's worn, but can't find any mention of the part or bush being available seperately. My VIN no is VF3**************[VIN obfuscated, can be read by forum staff]. Many thanks
- x 6962
(1) Gear Control Lever, part: 9810204980, £286.48
(6) Gear Selection Control Lever, part: 9800163780, £16.55
If any other item, let me know.
drayton11
Fantastic, thanks for your prompt help, it is indeed part no 6.
jakuboz
Hi, can I please have the following part numbers:
a: complete front suspension column, i.e., spring, shock, upper mount, upper mount bearing (if they come separately), dust seal and "rubber damper"
b: sway bar mount "assembly"- bushing and the metal "clamp"
c: front rubber brake hoses, clips (that hold rubber and metal hoses), brake caliper piston, dust seal, and inner seal/o-ring
Thank you!
Thank you!
- x 6962
@jakuboz: I assume this is for your 306 VIN ending in 228?
Suspension (10) Front Shock Absorber Mounting, part: 503160, £63.04
(1) Front Suspension Spring (1 Blue 2 Red), No Longer Available from Peugeot, part: 5002P3, £
(2) Rest Cup, part: 503137, £15.36
(3) Susp Rod Protector, part: 525413, £16.55
(2) - See above - part on spring diagram.
(1) Note OEM shocks no longer available.
Cheaper Option, Left, part: 1635540280, £60.49
Cheaper Option, Right, part: 1674697880, £60.49
(70) Flat Washer, part: 694619, £1.31
(71) Self-Locking Nut, part: 693437, £2.58
Anti-Roll Bar (1) Anti-Roll Bar (No Longer Available from Peugeot), part: 508188
(2)Anti-Roll Bar Bearing, Part: 509466, £28.19
(3) Anti-Roll Bar Bearing Clamp, part: 509739, £17.88
(4) Anti-Roll Bar Rod:
OEM, part: 508742, £94.48
Cheaper Version, part: 1634883680, £14.82
Front Brake Piping
(1) Brake Hose Front
OEM part: 480663, £45.31
Cheaper, part: 1623255280, £24.11
(3) Pipe Bracket:
Left, part: 4814H1, £13.57
Right, part: 4814H2, £13.57
(6) Brake Flexible Hose, part: 481494, £6.25
(11) Brake Hose, (No Longer Available) part: 4803J2.
Caliper Bits (5) Brake Piston Set (No Longer Available), part: 444874
(6) Columns Crew Set, part: 443914, £33.92
Front Brake Piping
(3) Pipe Bracket:
jakuboz
Yes, one and only, still rolling
From the suspension diagram (first) can I have number for part 4. I believe this to be what I called "rubber damper"
- x 6962
(4) This is the 'Bump Stop, part: 503326, but no longer available from Peugeot.
seanrx
- x 6
Hi.
Returning for my annual parts request!
The boot handle and it's micro switch assembly please.
My car's boot switch, it now does whatever it feels like.
Vin- VF7**************[VIN obfuscated, can be read by forum staff].
- x 1456
Items 13 and 14, bit pricey....!
seanrx
- x 6
That spacer at £19.
Is spacer meaning micro switch?
As all the Citroen micro switches on eBay? Shame they're not for Mk2's.
