2009 peugeot 407 coupe 2.0 hdi 163 bhp
michaelkaine
Unread post by michaelkaine »
Hi all, Greetings from the emerald isle, land of forty shades of green.
Im having a little problem with my peugeot 407 coupe 2.0 hdi 163 bhp , I had to dismantle the top of the engine to repair damage caused by timing belt sheering all its teeth and i mixed up the wiring connectors to the 3 solenoid valves at the rear of the air box and probably coolant temperature sensor and oil temperature sensor. Would some kind person happen to have a wiring diagram to steer me in some direction. I currently have no turbo boost, temp gauge ,oil temp gauge readings and so on. In hope.... Michael
Huskyxantia
x 928
Re: 2009 peugeot 407 coupe 2.0 hdi 163 bhp
Unread post by Huskyxantia »
Member MattBLancs will more likely be the man to help on this search member name MattBLancs hes very handy regarding things like this
:-D
x 2367
Unread post by MattBLancs »
Huskyxantia wrote: 30 Mar 2024, 22:27 Member MattBLancs will more likely be the man to help on this search member name MattBLancs hes very handy regarding things like this
Hi, thanks HuskyXantia,
I'll see what wiring diagrams I can lay my hands on shortly.
Just to check, are the wiring plugs absolutely identical? There's often raised plastic sections that will prevent one two pin socket from being switched with any of its near neighbours.
Huskyxantia
x 928
This might be what the owner could answer id say they might be , but we all know there might be differences , if you pop up what you find then the thread owner can check i guess.
:-D
