Hi guys,
Unfortunately one of my locking wheel nuts snapped a year ago so i got a new set from Peugeot last year. Annoyingly, possibly the second time i used the key on one of the wheels, another locking nut broke on me. Does anyone recommend a good set to buy that will fit my Peugeot 508 19" wheel please? maybe tempted to buy just 4 normal bolts to fair to avoid the situation again but i don't know the size i need if anyone does at all?
many thanks
Wheel Nuts!
- x 1941
Re: Wheel Nuts!
I would say ditch all the locking wheel bolts and just fit ordinary ones. Be aware that there are two types which need different size wheel spanners (17mm is one of the sizes) so try for the same size as you already have. It's not the end of the world if you get a different size bolt, just an annoyance to have to carry two different wheel spanners.
- x 6946
Re: Wheel Nuts!
See my post here- I used these limpet type that won't break off. Never had another issue and the quality was superb:Peugeot508gt wrote: 24 Mar 2024, 19:18 Does anyone recommend a good set to buy that will fit my Peugeot 508 19" wheel please? maybe tempted to buy just 4 normal bolts to fair to avoid the situation again but i don't know the size i need if anyone does at all?
many thanks
viewtopic.php?p=659965&hilit=limpet#p659965
- x 1056
Re: Wheel Nuts!
This for me is the best advice.Paul-R wrote: 24 Mar 2024, 20:15 I would say ditch all the locking wheel bolts and just fit ordinary ones. Be aware that there are two types which need different size wheel spanners (17mm is one of the sizes) so try for the same size as you already have. It's not the end of the world if you get a different size bolt, just an annoyance to have to carry two different wheel spanners.
One of the first things i do as soon as i get a new car is to remove the locking wheel bolts/nuts & replace them with standard ones. Not worth the grief they can cause, Especially if someone else is involved in removing & refitting your wheels. Even though i'm the only one who is ever likely to be removing & refitting wheels on my vehicles they still get thrown in the bin.
Dont think i've heard of anyone getting wheels stolen since the early 2000's.
- x 5674
Re: Wheel Nuts!
I was going to dump my locking wheel nuts. A puncture put some urgency into it as I couldn't find the key (new car at Christmas).
Turned out I had been beaten to it and they were normal-ish nuts but different to the other four on each wheel. Broke a socket trying to remove them.
These are the first 21mm nuts I have had on wheels. Tyre fitter got them off and loosened/re-torqued them all
- x 1941
Re: Wheel Nuts!
My daughter's Hyundai i30 has proper studs and 21mm nuts. Must be an oriental thing, even though it was made in Czechia.
- x 5674
Re: Wheel Nuts!
Civic had similar looking nuts but not 21 mm. 19 I think.
I never got round to swapping them. Found a huge pile at the tyre fitters but out of several hundred only two fit, the rest were all slightly different threads.
darbuck
- x 289
Re: Wheel Nuts!
All Nissan's have 21mm nuts, I think Toyota are the same so yeah your probably right on Asian yolks. I get rid of lock nuts straight away as well, had a SAAB 95 vector a few years back lovely wheels went to pull the drivers wheel off and ended having to get it drilled out destroyed the wheel I was disgusted had to buy a new wheel which took a while they were bloody rare.
Darren
Sialdriuk
- New User
Re: Wheel Nuts!
I had a locking wheel nut seized and rounded off had to get a professional out to remove it so now I've got normal ones in if they're going to nick them they will steal the whole car
