x 6956
You keep me on my toes, that's for sure :)
(3) Displacement Limiter, part: 503389, £4.08
(4) Shock Absorber Ball thrust Bearing, part: 503527, £33.31
Tom309
x 13
Unread post by Tom309 »
Hi, could I have the number for the front strut/shock absorber bearing & the top support mount for a Peugeot 307 (Vin VF3**************[VIN obfuscated, can be read by forum staff]) please.
x 6956
Let me know which item numbers Tom, otherwise the mounting kit (10) is:
OEM Original, part: 503177, £63.04
Cheaper Altenative, part: 1638380580, £40.52
NAM
Unread post by NAM »
Please will you provide the part number for a front suspension spring for a Citroen C5 Tourer.
The VIN number of my car is VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Nigel
NEW 50 Shades of Grey C5 Tourer 2016 BlueHDi 2L VTR+
C4 (62) 1.6HDi VTR+ (Feb 2020)
Silver Dream Machine: C4 Hatchback, 1.6 SX HDi (07) (July 2013 - Feb 2020)
C5 Tourer Exclusive 09/2Ltr HDi (Oct 2012-Sept 2021 146K miles
Xantia Estate Mk2 1.8LX V-Reg/2000 173K miles.
x 6956
(1) Front Suspension Spring, (marking 2 Green), part: 5002VK, £150.65
Note these are recommended to be replaced in pairs.
NAM
Thanks for the prompt info. Just wondered if there is a cheaper alternative or recommended generic part? I noticed that the previous post had a cheaper alternative listed. No worries if not. The part number 5002VK is the key bit of information for selecting generics?
Nigel
x 6956
5002VK is the official part number for the specific spring type for this exact vehicle. The springs are calibrated specifically for each vehicle and engine type and to compliment the dampers to ensure correct handling of the vehicle.
Citroen do not list a cheaper alternative in this case for the springs, as most X7s sold were hydractively sprung, and there probably wasn't a market for providing a cheaper spring given the relatively small numbers of this variant.
Tom309
x 13
GiveMeABreak wrote: 21 Mar 2024, 15:12 Let me know which item numbers Tom, otherwise the mounting kit (10) is:
Hi Marc, thanks for the very fast responese again, so I'm after the bearing (9), but (3) & (4) as well, in case I find an issue when I take it to bits.
x 6956
(3) Suspension Rest Cup, part: 503151, £28.36
You'll be better off ordering the kit then at (1) for the other parts.
Tom309
x 13
Yes, I was thinking that after I posted the reply. So thanks again.
Romtag
x 8
Unread post by Romtag »
GiveMeABreak wrote: 20 Mar 2024, 11:42 (2) Air Deflector Under Engine, part: 7013EF, £167.57
(70 Screw with washer, part: 692395, £1.46
(74) (MUL) CBLX RDL SCREW, Part: 6295N0 £0.78
I hope that isnt per screw!
Mark
Owner of a 2013 308 SW
x 6956
Indeed it is! And what's more these are supplied in a minimum of about 5-7 I believe, depending on which ones you need.
I got caught out years ago when I needed some cargo net clips for the C5. Had a pleasant surprise when they were only sold in a pack of 20! I think I still have some in the man cave.
cncjeff1
Unread post by cncjeff1 »
Hi, I was hoping that you could provide me with the correct part number for a diesel injector for a 2016 Berlingo, VF7**************[VIN obfuscated, can be read by forum staff].
The attached picture is of the sticker on the door post with the vehicle update information.
I am not sure that this is the correct place for this question, but I was hoping someone could tell me what I am doing wrong. I tried finding part numbers on catcar.info, but I can't seem to find the correct parameters. Can someone help?
Thanks in advance.
Jeffrey
x 6956
No need for the image Jeff, we get everything we need from the VIN.
(7) Brand New Bosch Injector, part: 9802776680, £594.79
Exchange Bosch Injector, part: 1610578480, £469.56
All include UK VAT @ 20%
It's always officially recommended to replace the injection pipes at the same time, given that they deform once initially tightened, loosened and re-tightened again.
cncjeff1
Are there individual part numbers for the injection pipes, or do you just have to bend them yourself?
