Steering angle sensor calibration process required
darbuck
x 291
Unread post by darbuck »
Hi Lads,
Can someone give me the steering calibration process for the C5 X7 please?
Darren
x 6955
Re: Steering angle sensor calibration process required
There is no written procedure Darren, it is part of a guided procedure within the Diagbox software itself that does it interactively.
darbuck
x 291
Hi Marc, ok thanks I may have another look to see if I can find it.
Darren
x 6955
It should be in the ESP menu, so run a complete diagnostic, let it finish, then select the ESP ECU from the list, then confirm, which should provide a second menu with options related to the system, which should include steering wheel angle sensor calibration - or should be within one of the related menus.
darbuck
x 291
OK thanks Marc I tried that the only thing that comes up is a graph.which stays at zero and says not calibrated. I have a u1205 after I finally got it to calibrate. Any suggestions on the repair for this. Is it the sensor itself or do I need to drive it first. I am waiting on a new glow plug relay and I have a few other things to clean up as well as giving it a good wash and valet inside before I can get it on the road, it's only been a 1 year and 5 months since I bought it🤔🫣
Darren
darbuck
x 291
It's alright It seems to have accepted the calibration and that the sensor Is good 😁. I actually used the Delphi scan tool I have which has gotten me out of bother with this car a few times.
Darren
x 6955
One down * to go.
darbuck
x 291
Yeah, I had p1350 and 1350 I now only have p1350 I discovered a rusted earth point behind the right side of the front bumper cover and cleaned it up which got rid of the p1351 so maybe it's an actual fault on these caused by a bad earth. So a partial win. Thanks for your help by the way.
Darren
