Double hydraulic stops
DS9
x 32
Re: Double hydraulic stops
Unread post by DS9 »
Oh dear, that doesnt help. Many thanks for checking for me, very much appreciated.
I'm hitting a dead end too :(
x 6959
It's because the dampers and the springs are all tuned to each specific vehicle's dynamics, from road handling to weight distribution, height etc., so have to be specific. I just may be down to the limited numbers of the DS9 and not being economically viable to engineer an after-market alternative for the perceived demand.
DS9
x 32
Sorry to bother you again but I've had an idea.
The PHEV version has the active scan suspension, this is for a car with batteries weighing another 300kg+ depending on version. There originally was the E-tense 225hp but then they brought out an E-tense 250hp. i test drove an E-tense 225hp and the ride was great.
Could you estabish if the suspension for these cars was the same on the rear? i dont know if the active scan works across all 4 wheels or just the front.
If all 4 struts are different could you get me part numbers and prices please? I might at a push be able to get the dealer to fit this.
x 6959
Not going to be an option because the DS9 active scan suspension uses a camera, body sensors, an ECU and 4 piloted shock absorbers.
There are 5 different setups for the DS9 and suffice it to say each have different part numbers for the dampers - but, this is where it gets complicated, so to simplify, there are several versions of struts for each of them
  • 4 Driven Wheels (Piloted Struts)
  • ICE Drive Train and Base Damping (normal struts)
  • ICE Drive Train with Variable Damping (Piloted Struts)
  • PHEV Drive Train with Base Damping and Non-4 Wheel Drive (Normal Struts)
  • PHEV Drive Train with Variable Damping and non 4 Wheel Drive (Piloted Struts)
The piloted struts are again different (different part numbers) to each variant above and have sensors in the struts to link to the suspension ECU.
These therefore will not work or be of any benefit without the other control systems like the suspension ECU or AMVAR unit, the accelerometer sensors, the height sensors or the specific camera module, BSI programming etc. etc.
I'm also 99% sure that DS won't fit any incorrect parts to the vehicles, for reasons of indemnity and retrofitting all this kit probably isn't a realistic option given the integration into the vehicle.
So to sum up, even if you could get any of the piloted dampers fitted, they wouldn't work.
DS9
x 32
Oh dear. Many thanks for the full explanation though.
i won't take up any more of your time at the moment, you've done more than enough for me recently. Appreciated!
x 6959
No worries, any time.
DS9
x 32
Hmmmmmmm.
I'd all but given up the ghost on this, but out of nowhere I have just come across something.
A while back i posted this https://kyb-europe.com/blog/double-hydr ... termarket/ and these would all but certainly be my preferred choice over Bilstein's or Monroe's.
I done a lot of websites where I enter the reg number and nothing comes up until I tried this. https://www.onlinecarparts.co.uk/car-br ... orber.html
Low and behold they are listing 2 versions of the KYB's as being compatible. One of the number 3348037 is very close to the 3348033 as described in the C5 aircross article.
I have just emailed the seller to double check they are comptible....... and I'd love them to say yes.
But it's a no..... just as i wrote the last sentence I received an email back...... FFS
Here is the result of compatibility check:
Unfortunately the spare part is available only at official dealers.
Shock absorber
KYB
339828
not compatible , it is not almternative
OEM: not compatible , it is not almternative
Shock absorber
KYB
3348037
God knows why they listed them then?
DS9
x 32
Just found out from the KYB catalogue the 3348037 and 3348038 fit the DS5.
x 6959
I'm really not surprised, as online car parts are invariable incorrect because of all the variations for the different engines and setups, but I am glad they double-checked, to save you a lot of hassle and wasted time and cost for something that was never going to work.
These are just selling the same units from KYB which we already know are not compatible from the previous research. :wink:
DS9
x 32
Thanks. For the time being I'm just going to have to give up on this until something arises, which it may not. I don't know if my expectations are too high after test driving the ultra smooth PHEV version.
I don't know if I told you but I got the suepension checked out at a local independent garage a couple of months ago, and as part of that I took the mechanic for a drive to see what he thought. At first he couldnt believe it wasn't electric, and that was starting on an incline, and then he said he's been in an Audi A6 a fair bit and he thinks it rides very much like that. Could be the case but if I wanted an A6 ride then thats what i would have bought.
In the short term I'll take the internal side boot surrounds off and heavy sound deaden over the rear wheelarches, and put a bit behind the rear wings. Might even put a bit inside the bootlid too. Then perhaps a bit of closed cell foam over the boot floor which already has dodmat on.
At the front it's a bit more challenging, hardly no space under the bonnet, so might do the wheelarches myself or get someone to do it. i don't want to get too invasive and rip out the internal carpet so will just stay with the MLV under the floormats, and perhaps try and stuff some of that insulating wool stuff down behind the carpet under the glovebox and on the drivers side too.
Like I've said before I do think the noise makes it worse than it probably is, and making things quieter should have some placebo effect into making me think the suspension has improved. The car is sleek and double glazed so quiet in these areas.
x 6959
Yes, I know what you mean - I've got it bad coming from Hydropneumatic and later Hydractive suspension on all my private cars since I was old enough to drive and now on springs and struts - totally bone-shaking, so at some point may have to go for the dual tube KYB progressive cushion alternative on the Aircross. The roads here are bloody awful as it is.
DS9
x 32
I'd definitely take the plunge if I were you, I could see the change being transformational. I do think the KYB's are a great bit of engineering and very cost effective considering the tech involved.
x 6959
GiveMeABreak wrote: 18 Mar 2024, 20:02 Yes, I know what you mean - I've got it bad coming from Hydropneumatic and later Hydractive suspension on all my private cars since I was old enough to drive and now on springs and struts - totally bone-shaking, so at some point may have to go for the dual tube KYB progressive cushion alternative on the Aircross. The roads here are bloody awful as it is.
Well scrub that idea!
I've just heard back from KYB regarding my enquiry about KYB Excel G shocks for the C3 Aircross and these are only an aftermarket version of the original system - so not Progressive Hydraulic Cushions, which are only for the C5 Aircross!
I'm glad I asked as it is misleading having the C5 Aircross PHC ones under the Excel G range, which are designed for PHC replacements only and this does not apply to any other vehicle or model!
So looks like I'm stuck with the ride quality and now have to have the rear exhaust carrier welded and lower front balljoint replaced because of the horrendously bad roads here.
DS9
x 32
That's really disappointing to hear, unlucky mate.
DS9
x 32
Hi
I did some sound deadening on the passenger side back wheelarch area this weekend, there isnt much there so I filled it out on various sides a fair bit with dodomat and closed cell foam. The top area was a pain and I couldnt get to it but generally happy with it.
I noticed what I think the suspension geometry is. On the front the bump stops would be inside the shocks but on the rear they are just a plasticky rubber thing that seems to sit on a suspension plate, looks quite rudimentary. X marks the spot so they seem to be hitting the right place. I turned the bump stop around to show the model number, the part comes up on a few latvian sites etc. Strange to see BASF on there, not sure if they are the same brand as made video tapes etc in the 1980s.
Just wondered if there was any way to perhaps easily improve the situation, either by upgrading the bump stops? or the other thought i had later was putting a but of high density rubber in the "cup"..... but I presume this would wear away?
