My 2010 Berlingo wont start. Shows a Camshaft sensor fault.
Camshaft Sensor, Crank sensor both changed.
When clearing fault it just returns when attempting to start again.
My next step is to send ECU off to be checked.
Has anyone dealt with anything similiar and could point me in the right direction?
Thanks for any help given
Berlingo Cam Shaft Sensor Fault that cant be deleted
Less2303
- x 1449
Re: Berlingo Cam Shaft Sensor Fault that cant be deleted
I would be checking for voltage from the ECU on one of the sensor wires, and checking continuity of the wiring back to the ECU.
- x 1056
Have you checked the valve timing is correct?
