Diesel additive pump
x 6955
Re: Diesel additive pump
I think I've asked for your VIN several times. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Jonathan coughlan
Unread post by Jonathan coughlan »
x 6955
Ok, so this is a later 2018 model, which I don't have a specific diagram for, but on the earlier version the additive pump had a earth and power and a CAN connection to the BSI. But if you have a later pump, it may have additional connections or be handled differently.
Jonathan coughlan
OK thanks a million .gonna try one more mechanic and if that's fails I'll only have one option .
x 1865
A gallon of petrol and a box of matches?
Jonathan coughlan
Haha I was thinking of going down that route
Jonathan coughlan
Update. Brought my berlingo to a new mechanic. He said he downloaded some psa software and reprogrammed my pump .he cleared the pump faults and the risk of clogging filter fault .van droves fine .put in under 10l of diesel into my van 2 days 30 secs later up pops the orange triangle (.i thought it was when you put in over 10l of diesel that triggers the additive pump fault)I'm out of ideas now at this stage .
Huse123
Unread post by Huse123 »
Did you solve your problem Jonathan?
