deNOx issue
x 6950
Re: deNOx issue
Use some Adblue additive to help remove and prevent crystallisation. Wynn's and Forte both provide these.
Huskyxantia
x 928
Re: deNOx issue
Unread post by Huskyxantia »
Intersting watch that was ,Hes a decent mechanic . Common sense type of guy
:-D
Sponk
(Donor 2026)
Re: deNOx issue
Unread post by Sponk »
DMC23 wrote: 20 Mar 2023, 14:07 DeNOx system 2
8 NOx content downstream of the deNOx catalytic converter 20 ppm
9 NOx content upstream of the deNOx catalytic converter 0 ppm
Hi.
I have a similar problem and the system is new to me but I'm wondering about up and downstream, shouldn't they show a result and not show 0 and 20 ppm which indicates either no connection or locked? My result is the same but it also shows that the signal is not available.
