The topic has been re-split Tom.
This one concerning the 308:
viewtopic.php?t=81326
This one concerning the Picasso:
viewtopic.php?t=81358
2015 1.6 Blue HDi 120 308 Adblue problem
- x 6947
Re: 2015 1.6 Blue HDi 120 308 Adblue problem
Tom309
- x 13
"The topic has been re-split" - That's good.
I've eventually found the problem to the "open circuit" Adblue/Urea Injector on my 308. The engine bay fuse F4 (5A) was blown.
Note that the fuse blew due to a injector failing short-circuit .
In case anyone is trying to fault find their car, after replacing the fuse:
I've measured the voltage on the connector when disconnected from the Adblue injector (Ignition on, engine not running)
Pin 1 to chassis earth: 12V
Pin 2 to chassis earth: 3.4V
Pin 1 to Pin 2: 8.7V
I only measure the connector when un-pluggeg as I working from the top of the engine.
