Bluetooth issue
This section is for General Enquiries or for Systems not Covered Above
Nikon101
Bluetooth issue
Unread post by Nikon101 »
so i have a Citroen jumpy 2012 and i cant get the Bluetooth to connect to my phone if it has Bluetooth
perhaps someone can assist me please thank you :)
x 6963
Re: Bluetooth issue
We'll need a VIN to determine which system you have, otherwise there's no way to advise. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Nikon101
Re: Bluetooth issue
hi yes SEE below thank you
Nikon101
Re: Bluetooth issue
GiveMeABreak wrote: 20 Feb 2024, 17:57 We'll need a VIN to determine which system you have, otherwise there's no way to advise. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Reason: Incorrect VIN Obfuscated
x 6963
Re: Bluetooth issue
Ok, so you missed the '7' out of your VIN, but I have it now.
So the reason you have no Bluetooth is that your RD4 system does not have Bluetooth, neither does it have the optional hands free add on pack that could be ordered when new.
So you'll have to make do with something like an aftermarket Bluetooth transmitter that operates via a spare FM radio frequency. There are plenty on amazon that are quite cheap and work via your mobile phone to the transmitter, which then sends out an FM signal to your RD4.
Something like this:
https://www.amazon.co.uk/Connector-Blue ... B094DGRHKD
Nikon101
Re: Bluetooth issue
GiveMeABreak wrote: 21 Feb 2024, 15:50 Ok, so you missed the '7' out of your VIN, but I have it now.
okay thank you for your help the device you mentioned i can have that fitted then or perhaps fit a new radio with bluetooth or even a
or perhaps something similar
x 6963
Re: Bluetooth issue
Just be careful - as the RD4 is not just your radio. It is the interface between you and the vehicle's options. If you replace the radio, you will lose functionality like the clock, trip computer, ability to turn on or off certain functions etc.
I suggest you stick to something simple like the above kit as you can easily wire it in yourself and you won't interfere with the RD4's functionality.
Nikon101
compatible radio for a jumpy 2012
Hi yes i have asked if its possible to change the radio but surely there must be a way of changing radio in a Citroen jumpy 2012 as the system is does not have Bluetooth or hands free possibilities , i have checked on you tube and there seems to be systems and able to put even screens in the palce but as the chap mentioed yesterday it effects the RD$ so what if is there has anyone change this i will be honest i know it effects the stalk controls but i dont use that anyway so please can you let me know or perhaps post a link on here for compatible radios thanks in advance
if they can put a man on the moon they can surly change a radio in Citroen :)
Reason: Post Moved to existing Topic
x 6963
Re: Bluetooth issue
Please don't create multiple posts for the same issue, it causes duplication of answers. I've moved this post to the original thread. :wink:
To follow on from my answer provided above, I didn't say it was impossible to do, I was just spelling out the consequences of replacing the RD4. This is not the place though to ask about radios - you need to get some advice from a car audio place or even dare I say it Halfords or a place like that who will no doubt have kits on display and will be able to advise.
You may likely need a compatible wiring harness to maintain steering wheel controls - but these are all questions you need to put to a a car audio specialist as we can't answer for the different manufacturers' systems.
I've provided a non-invasive approach using aftermarket add-on solutions that retains the original functions without butchering the vehicle, but of course you can replace the whole thing if required, as long as you understand the outcome.
Sloppysod
x 382
Re: Bluetooth issue
Unread post by Sloppysod »
I have just clicked on the link above and I can't see anywhere that says it transmits to an FM channel. I may wrong I have once before.😉
But, I think this is the best answer, full Bluetooth/aux input for less than £20, perfect.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6963
Re: Bluetooth issue
Bad example - there are loads of these that all work differently Stu, the one I think I linked to above works via the AUX changer.
This one is the FM transmitter type that I should of linked to:
https://www.amazon.co.uk/Syncwire-Bluet ... hdGY&psc=1
For £20 has to be worth a pop. Hands free calls and a music player and charger - what more could you want? :-D
Nikon101
Re: Bluetooth issue
thanks for the advice i have purchased a similar one as i dont reside in the uk i let you know how it goes if its a success if not i will seek help in my residential country in spectacular Spain
GeorgV
Re: Bluetooth issue
Unread post by GeorgV »
I have a 2014 Jumpy and I'm planning to replace the radio by a 2 inch model. I've removed the old radio and no problems seem to occur.
I've tested my new radio 'double inch) which seems to work fine. Due to a power issue at this moment I've removed it again until this problem has been sorted out.
I do realize I might miss some functionality at this moment (probably clock setting only). I'm not sure about any however. But the car is not complaining so I guess I can go ahead.
Have you opted to drive your Jumpy for a couple weeks without any radio at all? If that works fine, I guess you can consider replacing the existing radio.
An alternative I have in my mind is to install the old radio in the overhead storage (middle section). In parallel in other words without any speakers and without the antenna. This way the can bus wires would be properly terminated and if required I can use the radio to alter some settings. Only 5 wires (in my case) require to be extended.
