Tyre pressures
the2ems
- x 10
Tyre pressures
Just checking my tyre pressures for the first time. The plate inside the door frame says 2.1 bar all round, with light load. (2 people, no luggage?) That converts to 30.5 PSI, which seems very low to me
CITROEN C4 1.2 PURETECH C-SERIES EDITION S/S 5DR (2023)
- x 6947
Re: Tyre pressures
It's fine, and probably more notable because of your previous C3 which most likely had 16" steel wheels. Your new C4 will have 18" alloy wheels and therefore wider tyres have more contact with the road surface and can spread the load more than narrower tyres, therefore they need lower pressures.
Narrower tyres have to have higher pressure to withstand the loads with a smaller area of contact with the road surface.
the2ems
- x 10
Re: Tyre pressures
Ok thanks. That’s put my mind at rest.
So glad that this forum was recommended to me
