x 6954
Ok, so:
(1) Rear Suspension Cylinder
Left (Diam 40), part: 527272, NPF (no longer available). £-
Right (Diam 40), part: 527271, NPF (no longer available). £-
(2) Rear Suspension Saucer Sphere
Original OEM, part: 1638046280, £150.73
Citroen Cheaper Alternative, part: 1638377480, £77.08
(3) Cylinder Boot, part: 527264, £17.45
(4) Cylinder Pin, part: 527209, £3.88
(5) Cylinder Gaiter Clamp, part: 5280T6, NPF (no longer available). £-
(6) Square Seal (37,4X42X2,6), part: 527215, £7.91
(7) O-Ring Seal (DIAM 40 E 3), part: 527228, £2.58
(8) Cylinder Sliding Seal (DIAM 40 E 3), part: 527230, £7.43
(9) Weatherstrip Seal (DIAM 41X47 E 2,4), part: 527232, £3.55
(10) Cylinder Thrush Bush, part: 5272H3, £4.96
All inc. VAT direct from Citroen.
Billsy
x 9
Unread post by Billsy »
Hi mark
VR3**************[VIN obfuscated, can be read by forum staff]
Can you help me out with PN & price for the bonnet release handle? This is the one you feel for under the bonnet after it has been released.
Also there are four little rubber cushion/bumpers attached to the underside of the bonnet. Price each for them please
Cheers
x 6954
There are a few parts here, so let me know the items numbers to avoid me guessing which bits you want:
Billsy
x 9
8 & 40 please Marc
x 6954
(8) Engine Hood Safety Hook, part: 9823236680, £43.67
(40) Bonnet Stop, part: 873388, £15.60
Dustysweeper
x 20
Unread post by Dustysweeper »
Good evening, hope all is well.
I'm looking for part numbers for thermostat and temperature sensor (if it's separate) Also need alternator belt and both tensioners.
For VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Duncan.
x 1478
Thermostat - looks to me like it includes the temp sensor, you can just see the connector on the pic:
But here's the sensor anyway:
Belt and tensioners
Prices
Dustysweeper
x 20
Me again. I need the part numbers for the crankshaft belt pulley and the engine oil and gearbox sump plugs.
Many thanks
Duncan.
x 1478
Pulley 0515T3
You are supposed to replace the bolt, which is 1682800780
Engine Sump plug 031129, and washer 16828001680
Gearbox drain plug 22211 and washer 031338
Prices
darbuck
x 290
Unread post by darbuck »
Hi Marc, can you give me the part numbers for the differential drive shaft seals for my C5 X7 please
Darren
x 6954
(3) Driveshaft Gaiter Kit, Wheel Side, part: 3293C7, £56.33
(4) Driveshaft Gaiter Kit, Final Drive Side, part: 1610816380, £54.96
darbuck
x 290
Hi Marc, sorry for the confusion, what I need is the oil seals in the gearbox that the driveshafts go into if you can please.
Darren
x 6954
(1) Axle Housing Cap, part: 9822498280, £68.75
(13) Gearbox Lip Seal (Right), part: 1675689680, £28.80
darbuck
x 290
Thanks Marc
Darren
John77vts
Unread post by John77vts »
Hi,
Would it possible to please get the part number for the Air Intake Pipe between air filter box and throttle body. Citroen dealers won't give it and I'm struggling to source one without it.
My car is Citroen C4 Vts 180.
Vin = VF7**************[VIN obfuscated, can be read by forum staff]
Many Thanks
John
