- x 6948
(2) Front Wishbone, Left:
OEM Original, part: 3520P6, £507.42
Cheaper Citroen Alternative, part: 1607303080, £121.38
Tom309
- x 14
Hi, Please could i have the part number for the EGR valve and gasket on a 2005, 307 VIN VF3**************[VIN obfuscated, can be read by forum staff], thanks.
- x 1498
And prices
I have included the clamp at 7 as this is a Clic type and difficult to re-use - googling the part no suggests this is a repair clamp which is a bolt up type and is (a bit) easier to use - I fitted one of these on our C4 Picasso. No price given for an exchange valve; but I wouldn't buy a new one at £600 from Pug!
Tom309
- x 14
Hi Richard, that's brilliant. I was having a quick look at Ebay and there are new aftermarket valves including gasket from £28 upwards! (not sure about the quality though). So I'm having at look at branded ones as well - It won't be anywhere near £600 though. Thanks also for the clamp info as a screw version would be much better.
Billsy
- x 9
VR3**************[VIN obfuscated, can be read by forum staff]
Hi can please have the part numbers and prices for a rear view mirror, camera, module and the plastic cover?
Many thanks
Many thanks
- x 6948
Note: You have an outstanding after-sales campaign:
"KNK - Battery protector
The operation involves adding the protector of the 12V battery positive terminal."
So I'd get it booked in for the FOC work.
Internal Rear View Mirror
There are 2 possibilities, both are listed for this vehicle, so can't advise as to which one you need:
(5) Inside Rear View Mirror, Black FXT Black Cornelie, part 98088311XT, £277.82 or 98404100XT, £139.74
No camera shown for this vehicle (front or rear) and no panoramic visual aid, so not sure what you're after as you can't just retrofit these.
If any other parts from the diagram let me know the item numbers.
Billsy
- x 9
Thanks for the battery protector info Marc
The car has what I thought was a camera and little module at the top of the windscreen, behind the mirror trim. Maybe it's a sensor and not a camera. I think it's used for lane assist and auto braking system
- x 6948
Ok, so had another look in light of what you've said, and the camera is listed in a different section:
To make matters more complicated, there are 2 possible versions, both are listed as possibilities, so you'll need to check with the dealer which exact one you have.
You don't have the ARTIV radar system shown at (5), just one of the 2 possible cameras, so I'll list them both:
(1) Multifunction Video Camera, part: 1681924780, £581.42
(1) Camera Video Multifunction ESD, part: 1692663380, £441.42
They must have different functionality for different features, but not cheap whichever one!
Billsy
- x 9
Thanks again Marc. Can I have the info for the plastic cowling (6)? Is there just the one option for that?
Cheers
Cheers
- x 6948
You don't have the ARTIV (5) system, so the support bracket (6) won't apply.
You'll have one of the 2 camera options shown at (1) only.GiveMeABreak wrote: 13 Feb 2024, 16:28
Billsy
- x 9
Sorry Marc I mean the plastics that enclose the camera and module above the rear view mirror.
- x 6948
(6) Mirror Base Cover (Right) Black Cornelie, part: 98232252XT, £4.52
Mirror Base Cover (Left), Black Cornelie, part: 98232253XT, £4.52
teresam
Re: Citroen C5 2.2hdi.estate (2001)
Please can you help me with a components list/part numbers for the rear suspension assembly?
Thanks,
Teresa
Thanks,
Teresa
- x 6948
You need to supply the VIN and be more specific what you want - Struts, pipes, spheres etc.,
teresam
Thanks Marc,
The vin is VF7**************[VIN obfuscated, can be read by forum staff]
Need to replace the strut and sphere
