Brake MOT fail- Why?
rbruce1314
Unread post by rbruce1314 »
My vehicle has just failed MOT on rear brakes. When pedal is pushed Dials on tester come up immed. on fronts but on rear it takes a full 1/2 sec (nearer 1 sec) before gauge registers. Same for both sides. Nothing done recently (no fluid change etc.) so what is up?
x 94
Unread post by citronut »
what car is it
regards malcolm
Kowalski
Unread post by Kowalski »
Rostami
Unread post by Rostami »
Which car are you writing about?
If it has drum breaks on rear, then its usually one of the rear "pumps" that is failing. They are quite easy to replace, so it is a simples DIY job.
rbruce1314
Sorry folks- I thought you could all read. Car is as in my signature [:)][:)][:)]
Thanks Kowalski for the link- seems exactly the same problem.
x 1443
Bleeding the rear brakes should get you a ticket in the short term, but the problem will reappear. The gas is actually nitrogen and not air, and it's coming from a leaking sphere membrane - probably the anti-sink sphere, as this is most closely connected to the brake system. You'll probably need to consider changing some rear spheres sooner rather than later!
rbruce1314
Main spheres changed 3 months ago!
x 694
Unread post by Mandrake »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rbruce1314</i>
The very act of CHANGING any of the rear spheres will most likely let some air (real air, not nitrogen) into the rear brake lines, as the rear brakes run off the rear suspension.
Most of the trapped air should bubble out through the height corrector back to the tank if you do plenty of Citrobics after changing the spheres, but some may find its way into the brake lines and get trapped there. Because of this its good practice to bleed the rear brakes after changing any of the rear spheres...was this done at the time the spheres were changed ? (I'm betting not)
Regards,
x 694
Some people, like me, have displaying of signatures turned off on the forum and wouldn't see it.... it wasn't until a few weeks ago that people were refering to pictures of their cars that I couldn't see that I turned it back on and discovered they were in the signatures [:)]
Regards,
x 94
how dose one see ones signiture,i must be dafter than i first thought because i canay see what jaloppy you drive when it has an MOT
regards malcolm
x 694
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by citronut</i>
regards malcolm
Click on Profile then after logging in set "View Signatures in Posts" to "Yes."
Regards,
NiSk
Unread post by NiSk »
The rear suspension units are self-venting, replacing a sphere does not trap any air.
//NiSk
ActivaV6uk
Unread post by ActivaV6uk »
But the rear breaks are not, the problem is it only takes a very small bit of air in the lines to have an effect, however this could just as easly be furred up calipers.
The trick that myself and my dad do is just to put 2-3 large slabs in the back of the car and this will make the rear breaks work harder (suspension and breaks are lined at the back incase you didnt know), put them in 2 weeks every 6 months and your rear breaks will be fine.
Andy
jeremy
Unread post by jeremy »
Or keep your tools in it!
Jeremy
Kowalski
Taking your tools to a garage is asking them to disappear.
