- x 6957
(1) Axle Housing Cap, part: 9822498280, £68.75
(13) Gearbox Lip Seal (Right) 35x50-10, part: 1675689680, £28.80
Oliver53
Hi, can I request for the below gearbox (MLUC?) part numbers please?
- Diff oil seal left
- Diff oil seal right
- 5TH Gear 49x33
- 3rd Synchro Ring
- Gearbox Selector Shaft Seal
Thanks!
- 5TH Gear 49x33
- 3rd Synchro Ring
Thanks!
2000 ZX 1.4i
2006 Xsara Picasso 2.0i
2011 C5 2.3i (EW12A)
2003 Xsara Picasso 2.0HDi
1985 2CV6 Special
1985 2CV6 Special
dwjlivermore
Morning all
Could I please ask for part number for the following parts for VF7**************[VIN obfuscated, can be read by forum staff]:
Rear brake discs
Rear Brake pads
Handbrake shoes
Cruise control with indicator stalks
Many thanks
Darren
Rear brake discs
Rear Brake pads
Handbrake shoes
Many thanks
Darren
- x 1486
Diff diagram, 1 and 13 are the seals: Gearbox internals - 3rd Syncho only available as part of a kitOliver53 wrote: 30 Jan 2024, 21:07 Hi, can I request for the below gearbox (MLUC?) part numbers please?
- 5TH Gear 49x33
- 3rd Synchro Ring
Thanks!
Selector diagram
And the prices
- x 1486
Brake partsdwjlivermore wrote: 31 Jan 2024, 11:57 Morning all
Rear brake discs
Rear Brake pads
Handbrake shoes
Many thanks
Darren
Stalks - these are the ones fitted to yours, the cruise stalk is not shown separately even on the ones that are fitted with cruise - and there are loads of different variants but the one fitted to yours is not listed with the cruise option!
Prices - wouldn't give me a price for the OE discs.
BVL
Hi,
Could you please tell me if there is a pilot bearing on the crankshaft on the clutch side ( not the trowout bearing for the pressure plate ) where the clutch spline shaft rests in ?
Not sure and if there is what is the part number as i want to replace as well together with replacing clutch and flywheel.
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thanks,
Bart
Thanks,
Bart
- x 6957
Here are the other related diagrams, in case you want to look at the other components. Anything else, let me know the Diagram A, B or C and the item number:
A Clutch B Clutch Master Cylinder C Clutch Housing Gearbox
BVL
Hi Marc,
The shaft from the gearbox where the friction disk from the clutch slides on.
is the end of that shaft supported in a pilot bearing ?
if so the bearing is in the end of the crankshaft where the flywheel is mounted on.
Thanks,
Bart
Thanks,
Bart
- x 6957
I don't know what it is you want - Flywheel and Driveshaft assemblies:
- x 1486
Citroen don't use pilot / spigot bearings.
BVL
BVL
So peugeot also doesn't then ?
- x 6957
Thanks Richard
PSA use the same tech, engines and gearboxes etc. on all their models, so most likely not as Richard says.
- x 1486
I kind of meant all PSA cars, but only wrote Cit as that was on my mind!
MixerFistit
- x 14
I'm looking to get a n/s suspension arm for a C8 but am getting a discrepancy on cone size. 19mm seems to be the first choice on most sites that pop up but 17mm is given as an option too.
Also, does anyone have any brand recommendations. I don't mind aftermarket but I know ebay is generally useless and ECP not far behind - especially for a big lump like this vehicle.
Also also, Bit of a long shot - I've got new arms on an older dispatch that is now off the road and they'll have no more than a few 100 miles on them.
VF7**************[VIN obfuscated, can be read by forum staff] I don't suppose they have the same arms I can salvage seeing as the C8 is it's nephew?
Many thanks
Many thanks
307 CC 2.0 HDI
Sold/dead
Mk1 Dispatch 06 Face lift - 2.0 HDI - RHZ (sold)
2x xsara picasso 1.6 HDi
2x mk1 C4 Pic and a mk1 C4 GP
1x mk2 C4 Pic
C8 2.2.hdi (6 seat Exc) van/can
207cc 1.6 hdi (project)
Sold/dead
1x mk2 C4 Pic
