Good morning everyone, sorry for my English. I am Carlos from Spain!
Here is my VIN: VF7**************[VIN obfuscated, can be read by forum staff], Citroen C5 (X7) 2.0 Hdi 16V FAP 138 CV automatico
When the engine is at low temperature, everything goes perfectly. When the temperature stabilizes, the idle is increased to 1000 rpm. I've looked at everything stated on the forum and I don't see any possible solution. Any suggestions?
Thanks in advance!
Idle is turned up to 1000 rpm in N or P, not D or R with hot engine. Perfect cold.
xcrs2000
darbuck
- x 291
Re: Idle is turned up to 1000 rpm in N or P, not D or R with hot engine. Perfect cold.
You need to plug it in and get trends off the fuel rail and MAF sensor and coolant temperature sensor. The car might think it's cold if the MAF which integrates an air temperature sensor into its circuitry or the coolant temperature sensor is reading incorrectly.
Darren
xcrs2000
Thanks darbuck!
The MAF sensor was cleaned and everything goes well !!!
Regards.
CR.
Regards.
CR.
darbuck
- x 291
No problem glad to help
Darren
