x 6948
That's correct - all checked - it's in the Cylinder Bock Diagram.
darbuck
x 289
Unread post by darbuck »
Brilliant thanks Marc
Darren
quintet
x 44
Unread post by quintet »
Hello, would it be possible to get clarification for the part numbers for the nsf and osf door catch mechanisms for a peugeot 307? i actually got the part numbers from a dealer today but putting them into a search is throwing up all sorts of gibberish! maybe i wrote them down wrong although i have sourced a NSF lock mechanism. Whilst i've been doing a lot of searching there has been a lot of near identical units being available but i don't know if they are compatible, is it possible to check? anyway this is the chassis number VF3**************[VIN obfuscated, can be read by forum staff] and the catch mechanism part numbers i was given are nsf 9135 n6 and 9136 p2 for the osf. According to the dealer these are no longer available so i'm hoping there's an alternative that might work. RP number 1033489.
thank you, apologies for that message being a bit long winded!.
Music keeps me going.
x 1056
Unread post by wheeler »
That VIN is not correct, think i have the correct one now though (if your reg ends in ONM?)
If thats correct so are the part numbers the dealer gave you & both are showing as no longer available from the factory like they said.
x 6948
quintet wrote: 18 Jan 2024, 20:28 Hello, would it be possible to get clarification for the part numbers for the nsf and osf door catch mechanisms for a peugeot 307? i actually got the part numbers from a dealer today but putting them into a search is throwing up all sorts of gibberish! maybe i wrote them down wrong although i have sourced a NSF lock mechanism. Whilst i've been doing a lot of searching there has been a lot of near identical units being available but i don't know if they are compatible, is it possible to check? anyway this is the chassis number VF3**************[VIN obfuscated, can be read by forum staff] and the catch mechanism part numbers i was given are nsf 9135 n6 and 9136 p2 for the osf. According to the dealer these are no longer available so i'm hoping there's an alternative that might work. RP number 1033489.
Had the correct VIN, but as said they're not available from the dealer, but the parts are correct, shown at (1)
quintet
x 44
Ok thank you both, at least i know i do in fact have the correct part number, the nsf one ive found is in greece & is going to take a month to arrive, as for the osf.....well, right now i just can't find one :(
dylan26__
x 22
Unread post by dylan26__ »
Happy friday! Could i please get the rear shock absorber lower nut & bolt for VF7**************[VIN obfuscated, can be read by forum staff]
and also please the front (left) parking sensor for VF7**************[VIN obfuscated, can be read by forum staff]
x 6948
(2) Bolt, part: 522316, £6.11
(4) Nut, part: 522076, £3.73
Obstacle Detection Sensor Front Outer (to be painted) , part: 9677783280, £164.53
StrictlyConfidential
x 5
Unread post by StrictlyConfidential »
What is the part number for power steering fluid for VF7**************[VIN obfuscated, can be read by forum staff] ?
x 6948
You need Total Fluide DA for your Power Steering System.
You can get this from Total or other suppliers in 1 litre containers.
https://www.ebay.co.uk/itm/165433119502 ... gL3l_D_BwE
x 5
GiveMeABreak wrote: 23 Jan 2024, 18:12 You need Total Fluide DA for your Power Steering System.
Am I correct in saying that this would be PSA S71 2710 standard fluid?
x 6948
Yes.
There is only one product of Total Fluide DA, exclusively for the suspension and power steering of specific PSA vehicles.
x 5
GiveMeABreak wrote: 23 Jan 2024, 18:15 There is only one product of Total Fluide DA, exclusively for the suspension and power steering of specific PSA vehicles.
Got it.
Thanks Marc
dylan26__
x 22
What reverse bulb does my car take? VF7**************[VIN obfuscated, can be read by forum staff]
danlat1415
x 24
Unread post by danlat1415 »
Please could I get the part number for rear wheel bearings?
