Citron, C3 EGR wiring
malcolm6969
Can anyone help me what the five wires on the EGR plug should be reading with the ignition on and the car not running or how to test them. Thank you
- x 6950
Re: Citron, C3 EGR wiring
I'll need your VIN to check the system you have. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
malcolm6969
VF7**************[VIN obfuscated, can be read by forum staff] firstly thank you for replying .it is a five wire conection and i would like to know what wires should read unconnected then connected or where i may get a service sheet for egr its a pierburg.its not just about bolting a knew one on i would like to test everything along the way if possible.ive watched many videos and loadsa googling but cannot find information i want.befrore removing the launch machine i used says egr valve open cycle ratio was -4.6 . when i striped egr off and took motor off motor would be jerky and when built up of the car but plugged in didnt seem to move the valve at all ,again i appreciate your help cheers
- x 6950
| Description | Minimum tolerance | Nominal value | Maximum tolerance |
| Electric motor supply voltage | 10,5 V | 13,5 V | 16 V |
| Motor resistance | 2,04 ohms | 2,40 ohms | 2,76 ohms |
| Supply voltage of the EGR valve sensor | 4,75 V | 5 V | 5,25 V |
| Range for signal in closed position, of the EGR valve position copy sensor | 0,95 V | 1 V | 1,05 V |
| Range for signal in open position, of the EGR valve position copy sensor | 3,95 V | 4 V | 4,05 V |
| Supply voltage of the by-pass sensor/Exhaust gas recirculation heat exchanger | 4,75 V | 5 V | 5,25 V |
| Range for signal in exchanger position, of the by-pass sensor/Exhaust gas recirculation heat exchanger | Above 0,5 V | - | Less than 1,5 v |
| Range for signal in by-pass position, of the by-pass sensor/Exhaust gas recirculation heat exchanger | Above 3,5 V | - | Less than 4,5 v |
| Channel No. | Allocation of the tracks of the connector |
| 1 | Sensor + 5 V supply |
| 2 | Engine fuel system - |
| 3 | Earth |
| 4 | Engine fuel system + |
| 5 | Sensor signal |
| 1 | Signal |
| 2 | Earth |
| 3 | Power supply +5 V |
Pinout
1297 is your EGR, powered from the Engine ECU 1320
