leak
406 V6
- x 8400
lighteninguk
ivan olsen
martyhopkirk
Dave Bamber
Mosser
The water in my old 950cc mini used to run in through the centre of the window, down through the speedo, and into the tiny ashtray, in the end after trying to stop the leak for months, i just drilled a small hole in the bottom of the ash tray and used some fish tank air line pipe to drain the water straight out of the ashtray and down through a hole i drilled in the floor to outside !!, passengers used to be mesmerised watching the waster come in, run down through the speedo (behind the glass!) and into the ashtray and out through the small silicone pipe !!,
It eventually caught up with me in the end, as the speedo internals rusted and the needle must have siezed onto the cable drive as the speedo needle went round faster than the wheels were turning in the end !!, it used to spin so fast you couldnt see where the needle was!!
