Hi all, Question.....
Are the rear suspension arms from a Xantia estate the same as the saloon? and will they fit onto a saloon? They look the same, both same spec. I have checked pr-net but not too clear about it. The bearings seem to be going on my Xantia saloon, creaking as it rises up and going over bumps. I have found an estate that I can get them off for only £45 if I remove the myself.
Can you help?
Paul.
Forgot to say it's the nearside rear arm.
Rear suspension arms
JohnD
- x 72
- x 1238
If the donor car has done any sort of mileage they might be in a similar condition. New bearings are not to difficult to fit, you can get the outer ring out of the arm quite easily by running some weld, with a stick welder, around the inside of it, when it colls the ring will shrink and you can quite easily remove it with a couple of screwdrivers.
GFS do the bearings for £6:50 each or a complete repair kit for £21:00 I have just noticed that the estate bearings have a different part no and are dearer, so that should answer your question. If you are going to replace them I would do both sides.
- x 1238
wrinklet1
JohnD
- x 72
adzbaby
wrinklet1
wrinklet1
- x 1238
wrinklet1
Right, bought a suspension arm repair kit from GSF. Had a look at it and it seems fairly straight forward providing the diagram on the box is correct. I will have to phot the bolt and arm/bearings as I remove them . Any other tips??
Starting the job in the morning (I hope) providing it doesnt rain....
Paul
Paul
mpr1956
Hi there, I did mine a couple of months ago, no real problems.. but make sure you use ALL the parts in the kit. I found that after I removed (i.e. chiselled and generally mangled) the plastic sleeve from inside the arm, then there was a small lip showing of the bearing carriers which allowed me to tap out the carrier from the opposite end with a screwdriver, working around a bit at a time. It's well worth doing a search on here and reading through peoples experiences..
wrinklet1
wrinklet1
jeremy
