dylan26__
- x 22
Can you maybe check for my girlfriends car as it will be the same part just from a newer DS3 i believe the part number may be 9682115680 and if so please just confirm this. (2) from the diagram
Her Vin is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6956
Yes, the pipe is showing up on her vehicle:
(2) Refrigerant Pipe, part: 9678393980.
There is no 9682115680 part coming up for this vehicle.
dylan26__
- x 22
if it shows without my vin what part is this showing as then? i can see whatever shape it is on the diagram matches mine to a tee. My gf's one appears to have a slightly different compressor thoughGiveMeABreak wrote: 14 Jan 2024, 11:29 Yes, I checked 3 times, and with your VIN it is removed. Not sure of the reason for that, so hence a check with Citroen.
- x 6956
They are all different - so I can't advise as they are specific to engine type, build date, gearbox type etc. That's why we only go by the VIN to ensure correct part for the correct engine / build date etc. So not sure why they are not listing it for your vehicle, but if you do run it by Citroen, let us know what they say as to why it's not being shown, unless a database error.
- x 1485
These are the pipes for the DV engine type:
Yours is RP 12204, and has MCE type gearbox.
It looks to me like there is a mistake in the database as the first one listed apparently fits nothing as all gearbox types are excluded! I imagine this is the bit for yours, but it's NFP anyway....
Huskyxantia
- x 901
GiveMeABreak wrote: 10 Jan 2024, 17:07 Same vin, can i have part numbers for glow plugs please marc.
Husky.
- x 6956
OEM Original Glow Plug, part: 5960E6, £37.54 each.
Cheaper Alternative, part: 1682245080, £17.36 each.
Huskyxantia
- x 901
Brill thanks marc
Husky.
darbuck
- x 291
Hi Marc, can you give me the part number for crank bearing end cap bolts for my 2.0 hdi C5 X7 please?
Darren
- x 6956
(5) Engine Connecting Rod Bolt, part: 060737, £21.80 (ea).
darbuck
- x 291
Hi Marc sorry no it's the bolts for the cap that sits under rear main seal
Darren
- x 6956
You'll have to let me know which items as this diagram and the ne above are the only 2 parts diagrams for the crankshaft components.
darbuck
- x 291
Hi Marc, they're not shown in the diagram. I'll just have to bring to an engineering supplier I think.
Darren
- x 1056
Is it number 8 in the pic you are after? Please note this has not been checked by VIN as i dont know it but looks like its part no 13275 £1.21 inc VATdarbuck wrote: 18 Jan 2024, 12:39 Hi Marc sorry no it's the bolts for the cap that sits under rear main seal
Once confirmed this is what you are after needs checked by VIN.
darbuck
- x 291
Yeah that's it thanks wheeler.
Marc might check by VIN for me.
Darren
