x 1492
Front, doesn't give the size:
Rear
Prices
Battery stated is: 12V BATTERY L3-70AH-760A-AGM Doesn't actually give the size, but it's usually 096. £303.91 - sure you can do better elsewhere!
Huskyxantia
x 920
Unread post by Huskyxantia »
GiveMeABreak wrote: 04 Jan 2024, 17:39 Image
(10) Declutching Master Cylinder, part: 2182C8, £120.94
Marc same vin , part number for the small top coolant hose from top of rad to the thermostats housing inlet it has a curve
Thank you.
:-D
x 6945
(1) Radiator Water Inlet Hose, part: 1351VT, £35.78
Huskyxantia
x 920
Wheres the temperature sensor located on these marc ?
:-D
x 6945
(2) Water Temperature Sensor, part: 1338C1, £67.00
StrictlyConfidential
x 5
Unread post by StrictlyConfidential »
Hi,
Could I please get part numbers for Aux Belt tensioner, 17mm bolt and the Aux Belt itself for VF7**************[VIN obfuscated, can be read by forum staff]?
I believe they are parts 4, 5 and 72 from this picture if I'm right https://ibb.co/168Nh6T
x 6945
(72) Bolt, part: 9675976880, £6.37
(50) Aux Belt Kit
OEM Original, part: 1611278480, £552.71
Alternative Cheaper Kit, part: 1687682980, £483.32
dylan26__
x 22
Unread post by dylan26__ »
Hello, please can I get the rear spring lower and upper cup (rubber) part number?
x 6945
(5) Rear Spring Upper Cup, part: 516532, £15.30
(6) Rear Spring Lower Cup, part: 516439, £2.51
Huskyxantia
x 920
GiveMeABreak wrote: 10 Jan 2024, 19:25
Same car same vin , oil level sensor location & part number please marc, i may of possibly caught mine when replacing the clutch master cylinder the other day.... thanks
:-D
dylan26__
x 22
Happy Sunday, Can i get the air conditioning pipes from a/c compressor to the condenser in the diagram it's part 2 i believe.
Also if i can get the rubber stands that go on the condenser itself too. its part 3 &4 from the condenser diagram.
x 6945
There is no (2) pipe coming up for your vehicle, it is not listed, so best check with Citroen.
(3) Elastic Dowel, part: 1312A3, £1.09
x 6945
Huskyxantia wrote: 13 Jan 2024, 19:38Same car same vin , oil level sensor location & part number please marc, i may of possibly caught mine when replacing the clutch master cylinder the other day.... thanks
This is a combined oil temperature and level sensor:
(19) Oil Gauge, part: 1131G2, £116.80
dylan26__
x 22
GiveMeABreak wrote: 14 Jan 2024, 11:15 There is no (2) pipe coming up for your vehicle, it is not listed, so best check with Citroen.
there must be lol! i can see it with my own eyes. how strange is that. thank you though!
x 6945
Yes, I checked 3 times, and with your VIN it is removed. Not sure of the reason for that, so hence a check with Citroen.
