Eolys?
x 6947
Re: Eolys?
This indicates the fuel additive supply pipe or the tank. I take it when you added the Powerflex in May that you also reset the additive counter in the engine ECU?
linksys11
Re: Eolys?
Unread post by linksys11 »
Yes, we reset the ECU while charging. But I did not reset the ecu from the adit pump. They did this in September, when I had a recall to change the FAP filter. After changing the filter, it shows approx. 1080ml and in the ecu from the pump 96% I tried to make a prime today and can't find it. i have diagbox 9.149 I did a pump test and the pump turned on for 5 seconds, 3 or 4 clicks were heard. is such a pump test ok? I should mention that when adding diesel fuel, I look at the engine computer and see that about 2 to 3 ml is adding
x 6947
Re: Eolys?
That's fine. The additive counter is reset to zero from the engine ECU, so that it knows it has been topped up as the fluid level is NOT physically measured.
linksys11
Re: Eolys?
So, l must check the pipe. Is the pipe conected on diesel tank on diesel pump or directly on tank.
Maybe is cloged. The tank has a valve integrated. Can I fit a non return valve on pipe?
So B2E1A 7A meen low presure, but additive is still ading to diesel fuel? Is this ok
linksys11
Re: Eolys?
Are you shure for Powerflex. I have green conector
x 6947
Re: Eolys?
Yes
linksys11
Re: Eolys?
ok. So powerflex is ok.
I did another test of additive pump and its work ok an test says OK. If i test a pump,additive is pumped to diesel tank? Is this ok,or maybe to much additive in diesel
x 6947
Re: Eolys?
You don't want to keep doing it, put it that way, as the amount injected into the fuel tank is metered based on the amount of fuel added.
flugan
Re: Eolys?
Unread post by flugan »
Hi,
Need to fill up Eolys, my vin is VF7**************[VIN obfuscated, can be read by forum staff] what eolys do I need?
x 6947
Re: Eolys?
You need Powerflex Additive for this vehicle and build date.
flugan
Re: Eolys?
Thanks GiveMeABreak😊, whats odd is that the clips are green, thougt they should be blue if it was powerflex?
What build date does it have?
x 6947
Re: Eolys?
No that's not always the case. connectors are no indication of the Eolys type as there can be green or blue ones. Your build date code (RPO) is 12525 and you therefore require Powerflex.
SHREEVE
Re: Eolys?
Unread post by SHREEVE »
G'day
I need to fill up Eolys, my vin is VF3**************[VIN obfuscated, can be read by forum staff] what eolys do I need? and build number would be awesome, greatly appreciated 😁
doktordoc
Re: Eolys?
Unread post by doktordoc »
Hello, sorry for bad english
C4 Cactus 1.6 Blue HDI, 100 hp
Need Eolys , please help
How to hide Vin number for editor, thx
x 5677
Re: Eolys?
Just post it in full with no breaks and the forum software makes it unreadable to all but forum staff.
