Eolys?
- x 6955
Re: Eolys?
You need Eolys EXTEND (black) for this build date and the C5 X7 NOT Powerflex.
dandi
Re: Eolys?
Hi All,
After asking my mechanic to check and refill FAP additive to my C4 Picasso II 2.0 HDI (2016) -something went wrong as each time after driving for even a few meters there is a check-engine popping-up. The fault code is connected with FAP additive pump. Unfortunately I didn't receive a code number. Before refilling I hadn't had any check-engine popping-up. I think that something may have been done incorrectly around coding refill. Does anyone know, have information or link to video how to (Step by step) properly code refill? What could have gone wrong? I thought it was quite straightforward procedure. Now my mechanic suggest replacing entire additive box with a pump, and that's not something I will want to do especially I had no problems with additive before asking to check and refill.
- x 6955
Re: Eolys?
It' is possible they have not performed the procedure correctly. The additive counter must be reset to zero and on some models the system must be primed. We can't provide exact instructions as procedures are known to be slightly different from vehicle to vehicle depending on the additive system fitted. The procedure should be guided if using Diagbox software.
mihail
Re: Eolys?
????????????! ??????????, ?????????? ?? ??????? ??? DPF EOLYS EXTEND ? walker 83058 ? ?????????? Peugeot 508 hdi 2.0 2013 ??? ???????.
- x 5661
Re: Eolys?
Google translate from Russian:-
Hello! Tell me, are the additives for DPF EOLYS EXTEND and walker 83058 compatible? Car Peugeot 508 hdi 2.0 year of manufacture 2013.
- x 6955
Re: Eolys?
Please post in English only.mihail wrote: 29 Dec 2023, 14:37 ????????????! ??????????, ?????????? ?? ??????? ??? DPF EOLYS EXTEND ? walker 83058 ? ?????????? Peugeot 508 hdi 2.0 2013 ??? ???????.
If you want to know the correct additive fluid, post your VIN up as these can be specific to engine type as well as build date.
mihail
Re: Eolys?
Good!GiveMeABreak wrote: 29 Dec 2023, 17:17Please post in English only.mihail wrote: 29 Dec 2023, 14:37 ????????????! ??????????, ?????????? ?? ??????? ??? DPF EOLYS EXTEND ? walker 83058 ? ?????????? Peugeot 508 hdi 2.0 2013 ??? ???????.
vin: VF3**************[VIN obfuscated, can be read by forum staff].
Thanks for the explanation
- x 6955
Re: Eolys?
Ok so you have a Peugeot 508 (W2) and for (W2) models you use 'Eolys Extend', not Powerflex.
Lwalker199
Re: Eolys?
Could anyone help identify the correct fluid?
Would this work? https://www.ebay.co.uk/itm/114664905905 ... noapp=true
Any help is much appreciated! Thanks
- x 6955
Re: Eolys?
@Lwalker199: Hi, yes, you need Powerflex additive and the stuff in the listing you linked to will be fine. Don't forget you will need to reset the engine ECU additive counter with a suitable diagnostic tool.
Lwalker199
Re: Eolys?
GiveMeABreak wrote: 30 Dec 2023, 15:01 @Lwalker199: Hi, yes, you need Powerflex additive and the stuff in the listing you linked to will be fine. Don't forget you will need to reset the engine ECU additive counter with a suitable diagnostic tool.
Thanks, much appreciated!
linksys11
Re: Eolys?
Which Eolys for my C5 Aircross
VR7**************[VIN obfuscated, can be read by forum staff]
- x 6955
Re: Eolys?
Powerflex
linksys11
Re: Eolys?
Error With fault code(s) P1434, P1435 in the engine management ECU and fault code B2E1A in the fuel additive ECU
So pressure is to low,not level. I put 1l of powerflex on may 2023. Now i have this 3 codes but not on every refueling.
The fuel tank has a non return valve. Can i fit a non return valve on tube?
