Eolys fluid Citroen relay 2017
Relay17hdi
Post by Relay17hdi »
I’ve gone into limp mode and from what I can understand from the codes I’ve pulled, my eolys fluid is now too low to allow dpf regeneration. Consequently my dpf is now blocked.
Is there a particular eolys fluid that I need? My vin number is VF7**************[VIN obfuscated, can be read by forum staff].
Once I top up the fluid, am I right in thinking I just need to take it for a long run in order for a regeneration to occur?
I have attached the diagnostic report.
Cheers guys.
x 6011
Re: Eolys fluid Citroen relay 2017
Post by GiveMeABreak »
You need Powerflex additive and you must reset the additive counter after doing so, otherwise the engine ECU will not know you have topped it up (it is not physically measured).
Secondly, you have an outstanding after-sales campaign concerning your brake pipes - so I would get it booked into your dealer as soon as possible - the work will be free if required:
GYL - Brake pipes
The check of the assembly of the brake pipes on the vehicle. A risk may exist to damage brake pipes over time and in worst cases lead to a risk of brake failure
Relay17hdi
Thanks for your advice and also the recall info.
Relay17hdi
Happy new year!
Could you please let me know if this fluid will work?
https://www.ebay.co.uk/itm/284644319246 ... media=COPY
x 6011
That does NOT state Powerflex, so I personally would not touch it.
Relay17hdi
Ok thanks, would this one do it? I would need 3L I think.
https://www.ebay.co.uk/itm/294123233752 ... media=COPY
Otherwise I can get the psa kit but it’s £200 for 3L.
x 6011
That should do fine.
Add minimum of 1 litre.
