C5 X7 rear hydraulic pipe-hose stainless substitute
Skovgaard
Re: C5 X7 rear hydraulic pipe-hose stainless substitute
Unread post by Skovgaard »
Your 5270VG/VF tubes look very nice and I am interested in reselling them in Denmark so please contact me by e-mail
Oldbutnotdead
Unread post by Oldbutnotdead »
Hiya,
The unions in your last picture look correct for my C5 divider to rear right wheel strut pipe. Citroen part no is 5270 QA.
I'd be really interested in buying an assembled one - or if that is 3/16 copper pipe, just 2 sets of unions, seals etc would work.
Please let me know...
smiththeman
New User
Unread post by smiththeman »
Hi, I have a C5 2004 model ( old front). The right rear side suspension pipe has burst, can I get a replacement? All garages I have contacted have said I must scrap it. It seems such a waste.
Thanks for any help.
x 8158
Contact Chevronics in Hitchin tel: 01462 455280 and they may be able to help. Failing that try BL Autos tel: 01707 327555 in Welwyn Garden City who to my knowledge do have a selection of older pipes. I am sure there are other specialists around and if you look on our forum list of recommended garages you may find one closer to you. Good luck :)
Oldbutnotdead
Spoke to James at Chevronics yesterday- he had a dig round, they now have 3 5270 QA pipes listed (I bought the 4th one) so thanks for the top tip @mickthemaverick :)
marco1956
Unread post by marco1956 »
Hi Svod
Are you still manufacturing the C5 X7 rear hydraulic pipes?
My part number is 5270QS which is a solid pipe - is your flexible pipe a direct replacement for this?
If so how much including shipping to the UK.
Thanks, Mark
Bigzed
Unread post by Bigzed »
interested in both 5270vf and 5270vg ( left and right ) pipes.
Please PM with availability and price.
Thanks.
bishopwatusi
Unread post by bishopwatusi »
Hi Zvod,
interested in both rear pipes..
Thanks.
Pete
Svod
x 25
Unread post by Svod »
Hi guys,
Sorry for not being active for so long. If you want pipe-hoses - please contact friend of mine: patamatbx@centrum.cz he is able to send you them :)
Martin (Svod)
EEE
New User
Unread post by EEE »
Hi everyone.
Part number: 5270VQ
Supply pipe front suspension.
I really need all the help I can get in finding this hydraulic pipe otherwise the car will waste… I have called dealer suggested to me but still can’t find it.
Please any help will be well appreciated.
bishopwatusi
Absolutely interested in a pair of these!
Bogdan_05
Unread post by Bogdan_05 »
Please for price your execution
- 5270VG C5 X7 right
- 5270VF C5 X7 left
Thank you
Svod wrote: 28 Mar 2023, 15:11 Hi everyone,
Two years ago I was forced to change rear hydraulic pipes on my ’09 x7 2.2HDi cause one of them leaks. Whereas the pipes was unavailable to buy here I decided to create substitute from original. I was working on it with my colleague. We tested almost 10 pairs during last year and half and we can now manufacture them for C5 X7
Citroen numbers for them are:
- 5270VF C5 X7 left
Tubes are similar to original, except they are not made form zinc steel, but from stainless to ensure long life. Next difference is that they are separable to 3 pcs (1st one is stainless steel pipe, 2nd one is rubber hose, 3rd one is stainless upper part which is connected to rear hydraulic piston). Rubber hose is certified for use with more than 300 Bar pressure, but even if somewhere in future hose starts to leak, it is possible to change only the hose. Not whole pipe.
We want to make first larger batch and to specify the price I’m curious if some of you want to buy those for your C’s.
Let me know if you are interested or if you have any questions.
- Actual 1:1 original version
- First version with shorter stainless tubes
Svod
x 25
Hi guys,
Martin (Svod)
Bogdan_05
Please for price for your stainless rear hydraulic pipes
- 5270VF C5 X7 left
Thank you for you support!
- 5270VF C5 X7 left
Dunkah
x 11
Unread post by Dunkah »
Hi svod, good work, congratulations.
I don’t suppose you might consider re manufacturing the steering pipes at all. They come up in the forums time and time again and are no longer available or manufactured by Citroen, I certainly would buy a set or two if they were available.
