Hi All,
Just noticed that with my car on the drive, the driver's side is sitting lower than the other (maybe 10-15mm) - seems the same front and back. Is this a problem? Any theories?
I had the rear bushes etc. done about 40k ago and an new shocker fitted to the n/s front about 10k ago. Other than looking a bit odd (if you look carefully) it drives perfectly
Ron
ZX suspension
jeremy
- x 1436
There was a thread on this a while back - quoting almost the same number. Out of interest I went and measured the ZX TD we had at the time - and found the same. So it looks like they could all be like that (perhaps I should check the current one)! It may well be simply to do with the weight of the engine being offset - on LHD cars this would be compensated by the driver being on the other side, but is compounded on RHD cars. Just have a check to make sure the spring is OK. Otherwise, find a large passenger to counterbalance it [:o)]
rabenson
