admiral51
(Donor 2026)
x 394
Unread post by admiral51 »
Thanks Marc much appreciated.
Colin
kuhar
x 3
Unread post by kuhar »
GiveMeABreak wrote: 07 Dec 2023, 10:22 For all non-collaborative vehicles, so not for the following:
PSA use Freecor Coolant.
Ready to use:
2 litre: 1637756380, £11.06
5 Litre: 1637756480. £23.99
10 Litre: 1637756580, £40.94
20 Litre: 1637756680. £101.75
Sorry Marc to bother you again, forgot to ask you how much of the stuff goes in it (car) after I dilute it 50/50 (is it 50/50?)? I've asked the dealership, but they are clueless...
- Marko
x 6960
This is ready mixed and ready to add:
Huskyxantia
x 794
Unread post by Huskyxantia »
Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]
:-D
walter
x 4
Unread post by walter »
I’m after the part number for the sump plug washer please
VR7**************[VIN obfuscated, can be read by forum staff]
x 6960
@Walter:
(2) Engine Oil Drain Plug, part: 031139, £2.12
x 6960
Huskyxantia wrote: 13 Dec 2023, 14:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]
Husky - for reference, please note that in the VIN there are no character 'O's, just numeric 0's :wink:
(28) Engine Oil Pressure Switch, part: 1131K9, £66.28
walter
x 4
GiveMeABreak wrote: 13 Dec 2023, 15:25 @Walter:
The washer please not the plug looks like no3 on picture thank you.
x 6960
Oops :roll: , (3) Plug Seal, part: 016488, £2.40
Huskyxantia
x 794
GiveMeABreak wrote: 13 Dec 2023, 15:51 Oops :roll: , (3) Plug Seal, part: 016488, £2.40
We all make mistakes !
:-D
Huskyxantia
x 794
GiveMeABreak wrote: 13 Dec 2023, 15:29
Huskyxantia wrote: 13 Dec 2023, 14:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
ok, so this is the wired type .
:-D
nomad123
x 5
Unread post by nomad123 »
Vin : VF7**************[VIN obfuscated, can be read by forum staff]
Hello, my engine temperature is fluctuating between 5 and 7 bars on the dashboard.
Driving with Lexia the coolant temperature is fluctuating between 68 and 78 degrees, up and down.
It can't reach normal operating temperature of around 83 degrees.
The main suspect is thermostat.
So I need part number for my vehicle.
I have found thermostat with this part number 1336Y9, is this the right part for my vehicle or not?
Thanks!
x 6960
@nomad123
1336Y9 is the complete outlet unit and includes ALL parts in the (1) in the diagram. I've included the temperature sensor alone in case that is what you are after.
(1) Engine Water Outlet Tank, part: 1336Y9, £201.46
(2) Water Temperature Sensor, part: 1338C4, £67.00
nomad123
x 5
Thank you very much. :)
drayton11
Unread post by drayton11 »
Hi My VIN is VF3**************[VIN obfuscated, can be read by forum staff]. Could I please have the part number for the Automatic Gearbox valve body. Many Thanks.
