x 6948
Bonnet Control Fastener Clip, part: 792843, £1.10
(3) Trunk Lining Right, part: 98277907ZD, £289.63
(5) Floor Console Face, part: 98247337XU, £108.04
kuhar
x 3
Unread post by kuhar »
Hi Marc,
Any idea what kind of coolant/antifreeze goes into Citroen c4 Grand Picasso?
Specific brand or number or w/e helps with finding the correct stuff.
- Marko
x 6948
For all non-collaborative vehicles, so not for the following:
(C1 (B1) / 108 (B1) - (1.2 -litre petrol engine)
C-CROSSER (I4) / 4007 (I3) - (2,2 litre HDI engine)
C4 AIRCROSS (J4) / 4008 (J3) - (Petrol and diesel engines)
C-ZERO (S4) / IOn (S3)
E-Méhari
PEUGEOT PICK UP (KP0)
Commercial vehicles)
PSA use Freecor Coolant.
Ready to use:
2 litre: 1637756380, £11.06
5 Litre: 1637756480. £23.99
10 Litre: 1637756580, £40.94
20 Litre: 1637756680. £101.75
gazzaman2k
Unread post by gazzaman2k »
Hello im after the part number for the Eolys powerflex fluid DEF fluid tank for the following please
Vin VF7**************[VIN obfuscated, can be read by forum staff]
2016 ds3 120hdi blue
old part number of 9815713080 on the tank but google is not bringing me anything only 2nd hand units,
i have tried a brand new 9815713180 and diagbox cannot even detect the pump when attached??? and there is another number 1613704680 which looks identical but says it fits C3 II yet the other says DS3 1.4 and 1.6?????
walter
x 4
Unread post by walter »
would it be possible to get the OEM part numbers for the oil filter air filter pollen filter and the diesel filter for Berlingo 2020 1.5 BlueHDi 75 K9 Van VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
x 1083
Unread post by Rp0thejester »
GiveMeABreak is not employed by anyone in FCF, he's an enthusiast just like us, please give him time to reply as and when he can. He's never been wrong on a part number for me.
admiral51
(Donor 2026)
x 392
Unread post by admiral51 »
Hi Marc,
Looking for the part number of the upper rubber seal on a Peugeot Partner Esplanade drivers side 2003
It is the one not on the door but sits just below the roof line if that makes sense.
Vin is VF3**************[VIN obfuscated, can be read by forum staff]
No rush asking for a work mate as he has replaced it after getting some duff info.
Colin
x 6948
As I'm not sure from the images on your other thread as to what exactly is the bit you want, here are the most likely ones, otherwise let me know:
(7) Door Weatherstrip (Right) on Body, part: 9023FF, £118.06
(8) Door Weatherstrip (Right) on Body, part: 9023Z1, £103.88
(9) Drip Moulding Seal (Right), part: 9023NN, £54.49
x 6948
walter wrote: 07 Dec 2023, 18:55 would it be possible to get the OEM part numbers for the oil filter air filter pollen filter and the diesel filter for Berlingo 2020 1.5 BlueHDi 75 K9 Van VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
You also have a flag coming up for an after-sales campaign, ref HYX, concerning the following:
HYX - Under body protector
As customer satisfaction is our major concern, we would like to remind you that your vehicle cannot be driven off-road without specific equipment. Using your vehicle off-road means use on difficult terrain (construction site, rocky path, badly damaged roads, etc.) or on surfaces covered with vegetation (fields, grasses, forest lanes, …).The absence of this specific equipment might lead to some damages on the vehicle or a possible degradation of safety equipment. If you were to use your vehicle off-road, we invite you to contact as soon as possible your authorized repairer CITROEN that will inspect the vehicle and will propose you the adapted equipment available in accessory catalogue.
(8) OEM Oil Filter, part: 1680682480, £13.67
(6) OEM Diesel Filter, part: 9820226380, £40.07
(2)
OEM Air Filter, part: 9813908880, £29.78
Cheaper Citroen Air Filter, part: 1683830180, £20.18
walter
x 4
Did you get the OEM for the pollen filter does it give you a OEM for the HYX - Under body protector I may look for a second one thank you for your help.
x 6948
Missed the Pollen Filter:
(6) OEM Pass. Compartment Pollen Filters, part: 6447XF, £33.92
Cheaper Citroen Alternative, part: 1609998980, £18.19
The HYX is just an internal Reference for the specific after-sales campaign. There are different options for different engines, so the Campaign in this case is to discuss which one is suitable for you.
admiral51
(Donor 2026)
x 392
Thanks Marc bang on the money as always, part #9 is the offending article.
Think he also needs part 75, mentioned a clip broke.
Any idea if either are available or no longer stocked.
Cheers
Colin
x 6948
@Colin: Parts are all available unless I state otherwise. :wink:
(75) Clip, Part: 6991Y6, 0.47p each.
gazzaman2k
gazzaman2k wrote: 07 Dec 2023, 18:14 Hello im after the part number for the Eolys powerflex fluid DEF fluid tank for the following please
Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Hello any chance if you could help me? Not sure if you missed my post? You have replied to people after mine
Thanks 😊
x 6948
Must of missed that one,
(20) PEF Additive Reservoir, part: 9815713180, £254.24 direct from Citroen / DS Autos.
There is no other part listed and no replacement part shown, so this is showing as the original reference for the tank. The 9815713080 is similar bar 1 digit, so may be a typo by online sellers....
Ignore sellers 'compatibility' rubbish or their crappy databases, they are invariably wrong!
If you have told Diagbox under replacement parts, that it has been replaced and it is not being recognised or picked up, then you may have another electrical issue separate to the tank. Specifically check the electrical connections from the wiring at the tank connector (physical pins, wires and the wiring way from the tank connector). Please create a new topic on the relevant forum for further discussion if you like. :wink:
