Thanks for any insignts on the matter
M59 Berlingo Rear break light wire.
Deniskk
Hi, i'm tryint to find out which wire is the reverse wire in the berlingo. I know they arent color coded, but Idk how to figure out which is the reverse 12v and ground. Im trying to connect a reverse camera to it.
PaulC5
- x 667
Re: M59 Berlingo Rear break light wire.
The easiest way might be to remove a rear light and then follow the wires back in to the car from the reverse light bulb.
Deniskk
It was the white wire, number 4 on the connector.
