x 8386
I had some massive cracks in a pair of rears on my AX. MoT tester didn't even comment. I was not happy and swapped them before the next MoT as one was slowly loosing air and I hate that...
They dated from so long ago I could not decypher the date code... They may even have been original but certainly dated from way before the car came back home to the UK in 1018.
I use Black Circles every time. They deliver to my local place at the end of the road and have been perfect on every occasion I've used them.
For the AX you have to order anyway as hardly any tyre places keep suitable tyres in stock these days...
x 8110
CitroJim wrote: 26 Nov 2023, 12:47
Have you tried Hamleys Jim? :-D
x 1942
CitroJim wrote: 26 Nov 2023, 12:47... the car came back home to the UK in 1018.
As used by King Harald at the battle of Hebden Bridge?
x 2341
Unread post by MattBLancs »
Sidewall cracking VS MOT tester, that's mostly what puts the wind up me - one guy's fail is another's advisory us another's didn't even mention.
Unfortunately I am off to a different tester (my normal chap has gone AWOL guess is on holiday) so be interesting to see what level of pedantry I've put myself in for. It's actually where I go for the BlackCircles supplied tyres to be fitted usually and they do a decent job of that (even if the infamous Centreless Wheels are getting new rubber, never had a balancing issue)
x 3566
As detailed in the MOT inspection manual (along with other tyre related stuff I've not included here).
"When assessing cuts in a tyre, it is permissible to check whether a cut is deep enough to reach the ply or cord by using a blunt instrument to open the cut taking care not to cause further damage.
The following criteria should be used when assessing a cut in a tyre:
any ply or cord that can be seen without touching the tyre - fail
if by folding back rubber or opening a cut with a blunt instrument, so as not to cause further damage, exposed ply or cord can be seen irrespective of the size of the cut - fail
if a cut which is more than 25mm or 10% of the section width whichever is the greater, is opened with a blunt instrument and cords can be felt but not seen - fail
Before failing a cut, you must make sure it’s the cords that you can feel not a foreign object. If you’re not sure, then you should pass and advise.
When assessing lumps or bulges in a radial ply tyre, care should be taken to distinguish between normal undulations in the carcass, resulting from manufacturing, and lumps or bulges caused by structural deterioration."
https://www.gov.uk/guidance/mot-inspect ... suspension
x 2341
Spot on, will see if any cords are visible shortly.
Must get that CV off, managed to get the bottom ball joint's taper to pop loose with a good tap or twenty from the 4LB hammer. The euphoria of that little win (and a rumbling belly) made it a good point to pause for dinner :)
x 8386
mickthemaverick wrote: 26 Nov 2023, 12:51
:lol: Good shout Mick!
Paul-R wrote: 26 Nov 2023, 13:09
It's been about a bit has that car Paul ;) :lol:
MattBLancs wrote: 26 Nov 2023, 13:10 Sidewall cracking VS MOT tester, that's mostly what puts the wind up me - one guy's fail is another's advisory us another's didn't even mention.
bobins wrote: 26 Nov 2023, 13:28 Before failing a cut, you must make sure it’s the cords that you can feel not a foreign object. If you’re not sure, then you should pass and advise.
Indeed... All very subjective and the directive: 'If not sure, pass and advise' is so, so open to interpretation in so many ways...
x 3566
I was told by my MOT chap a few years ago that the ideal MOT tester is someone who knows little about cars but can follow the testing manual carefully !
x 2341
Ah, maybe that's is the grease escape route:
Strangely the clearly perished bit nearest the metal clip all seemed to be very intact and free from grease
x 2341
Numberplate lamps seem pretty dim, I wonder why?
Spoiler: show
at least that should be an easy fix!
x 8386
David Attenborough will be around soon. I believe there's life there previously unknown to science...
x 8386
MattBLancs wrote: 26 Nov 2023, 14:15 Ah, maybe that's is the grease escape route:
I once had that just before an MoT test, a little hole in the boot... On a Xantia as far as I recall... I stuck a bicycle patch on it and it passed fine...
It didn't last as the grease soon dissolved the adhesive. I never intended it as a permanent job and changed the boot as soon as I could. It was just a stop-gap to meet a need.
x 2341
Not a bad stop gap Jim!
I often wonder how long those split boots, with a longitudinal seam stuck back together with super glue, last in practice. I've no direct experience but from what I've read it sounds like they are very short term fix at best.
x 8386
MattBLancs wrote: 26 Nov 2023, 17:27 I often wonder how long those split boots, with a longitudinal seam stuck back together with super glue, last in practice. I've no direct experience but from what I've read it sounds like they are very short term fix at best.
Tried one once Matt.... It was a total and unmitigated disaster... It was a mystery to me - and still is - precisely what magic was needed to keep CV grease off the jointing surfaces whilst you valiantly tried and failed to get everything aligned... :twisted:
Maybe it was just me :-k
x 2341
Few pictures from earlier
CV as removed (quick hand wire brush before removed from shaft)
Post treatment from trust knot wire brush on the grinder
Post treatment with phosphoric acid
All the cool kids are fitting sexy blue CV joints, or something
Re greased joint
Re greased joint
Sent Attenborough home as had scrubbed it off (old toothbrushes are handy things!)
Led bulbs = dim, so standard T10's for now.
Old auxiliary belt and 3x2 = excellent wishbone deflector setup
