x 6956
(1) Front Spring (Ref 1 Yellow, + 1 White, + 1 Orange), part: 5002WS, £147.68
(2) Rest Cup, part: 5033C9, £15.89
(3) Rest Cup, part: 503151, £28.36
(4) Shock Bracket, part: 9813916080, £72.76
(5) Nut, part: 503615, £5.14
(6) Bump Stop Cup, part: 503371, £16.52
(7) Rod Protector, part: 525431, £17.03
(8) Bump Stop, part: 503370, £27.11
(9) Shock Thrust Bearing, part: 503563, £33.31
(11) Flanged Nut, part: 503623, £1.93
(51) PSA Suspension Stop Kit, part: 1638383580, £30.90
(1) Front Damper
Left Exhange, part: 1674699180, £91.79
Right Exchange, part: 1674699280, £91.79
Note: The following 2 parts already included above in the Spring parts
(2) Shock Rod Protector, part: 525431
(3) Flanged Nut, part: 503623
Billsy
x 9
Unread post by Billsy »
Billsy wrote: 22 Nov 2023, 09:17And my wing supports were held on with these:
I'm not sure which diagram you are referring to for the above, as they aren't shown on the wing Schematic: unless you are referring to a different diagram?
It's item 73 here. They look shorter than the headlight bolts (as per my picture above)
x 6956
Ok, so (73) in the diagram above are correct and the part number is 623006, the same as the ones for the headlights quoted before. So the wrong ones would appear to be in your photo above.
Billsy
x 9
ok thanks Marc
Can I get a price for a new key please
VR3**************[VIN obfuscated, can be read by forum staff]
x 6956
(1) (See Description below). Part: 9840149780, £204.78
Set of badge keys + back-up key and 433.92 mhz super heterodyne and front access+boot+smart device+hands-free starting since mad 1642976
Or set of badge keys + back-up key and 433.92 mhz super heterodyne and front access+boot+contactless starting since mad 1642976
Rr set of badge keys + back-up key and 433.92 mhz super heterodyne and hands-free starting since mad 1642976
Billsy
x 9
GiveMeABreak wrote: 23 Nov 2023, 10:20
Thanks Marc. "set of badge keys" does that mean a pair of keys? Do you know?
Can I get a price for a windscreen please?
x 6956
(1) Windscreen Glass, part: 1669671080, £460.24
As for the fobs, I can't be certain, so best to clarify that with Peugeot :wink:
MixerFistit
x 14
Unread post by MixerFistit »
GiveMeABreak wrote: 28 Aug 2023, 18:33 Image
(4) Engine Oil Gauge, part: 117462, £23.68
Hi, will this be the same for an 06 Dispatch also Rhz engine.
The Orange handle/stopper of mine has began to crumble too but the tip is solid metal thankfully.
https://www.ebay.co.uk/itm/165781340883 looked promising albeit 1 number out from your part given.
https://www.ebay.co.uk/itm/301103627344 this one seems to match (I'm assuming the colours don't matter?)
307 CC 2.0 HDI
Sold/dead
Mk1 Dispatch 06 Face lift - 2.0 HDI - RHZ (sold)
2x xsara picasso 1.6 HDi
2x mk1 C4 Pic and a mk1 C4 GP
1x mk2 C4 Pic
C8 2.2.hdi (6 seat Exc) van/can
207cc 1.6 hdi (project)
x 6956
@ MixerFistit: Please provide your own VIN here if you want the correct part for your vehicle.
MixerFistit
x 14
Oops forgot about that
307 CC 2.0 HDI
Sold/dead
1x mk2 C4 Pic
x 6956
So no, different part and part number:
(4) Engine Oil Gauge, part: 117463, £24.40 inc. VAT from Citroen
MixerFistit
x 14
Great stuff, surprised there's so much variation for simple things like dipsticks! But then my engine doesn't even match the manual properly lol
Thank you Marc
307 CC 2.0 HDI
Sold/dead
1x mk2 C4 Pic
Huskyxantia
x 901
Unread post by Huskyxantia »
Clutch needs to be replaced , is it a dual mass flywheel or normal ? Whats all part numbers clutch plate, thrust bearing , housing and the flywheel , vin VF3**************[VIN obfuscated, can be read by forum staff] a huge thanks.
:-D
x 6956
(9) New Flywheel, (DIAM 200 - 117 DTS), part: 0532L2, £494.33
(1)
OEM New Pro Clutch Kit, part: 205315, £388.80
Standard Exchange Clutch Kit, part: 205808, £178.97
x 1938
If the drawings are to be believed this is a solid flywheel.
